Old 03-07-2007, 11:55 AM
jeff markham's Avatar
jeff markham jeff markham is offline
Default C24 and Hear Technologies Hearback system?
Does anybody use the Hear Technologies headphone "more me" hearback
system with a control 24? If so, I'm curious how you patched in
in?
We're thinking of running the C24 Aux output to channels 1 & 2 and then
running 6 outputs directly from a 192 I/O to the other 6 inputs of the
Hear Hub.
Does this make sense?
Thanks
Jeff
ps: for reference ... http://www.heartechnologies.com/hb/hearbacksystem.htm
Old 03-07-2007, 12:58 PM
jre3132 jre3132 is offline
Default Re: C24 and Hear Technologies Hearback system?
I haven't used the Hearback system with a C24 but I did have a 6 channel headphone system in my first studio. that is exactly what I did.
let channels 1 and 2 (or stereo mix) run from the I/O into the aux in, aux out to the headphone amp input (as you said, input 1 and 2). all others can be connected directly from the I/O. The only thing that you'll have to watch is what level you keep the aux knob. With this configuration (and assuming you send everything out of protools at the same level), if you don't keep the aux turned up all the way, your channels coming directly from the I/O will be louder than your channels patched through the c24.
Hope that makes sense and helps.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 03-07-2007, 01:53 PM
perfect .. thanks much .. i'll report back on the Hearback system whenever
we can get the band that won't go away to go away ;-)
jeff
Old 03-08-2007, 06:54 AM
whenever we can get the band that won't go away to go away ;-)
I needed a laugh this morning. That is awesome.
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 03-16-2007, 12:45 PM
Studio Dweller Studio Dweller is offline
I recently got the Hearback system (hub + 4 personal mixers) and I love it. Great system for a very reasonable price. I'm running mine with a digital feed. I take the ADAT optical out from the 192 I/O directly to the Hearback hub. Via the patchbay, I have the talkback from the C24 normalled to analog input 16 on the 192 I/O and I do all routing in Pro Tools.
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 02-28-2011, 01:24 PM
Perfection7 Perfection7 is offline
Hy, i just received my hear back and i have a 192, i connect the adat output from 192 to adat input hub, but the hub is not receiving the audio and on my 192 i can see the leads sending audio, i see the outputs sending !!
Does any one know how to setup the protools output our if it is any think else??
Thanks
Ed. Muniz
192/Control24 and Hearback System tim carter Pro Tools TDM Systems (Mac) 6 02-28-2011 01:25 PM
Hear Technologies: Hooking up with 192? Joe Petrocy Tips & Tricks 9 10-19-2007 09:10 AM
C24/002R and Hear Technologies Hearback System tim carter ICON & C|24 2 08-05-2007 12:56 PM
002r and hearback system therecordinghouse Tips & Tricks 4 07-20-2006 09:00 AM
OT: Hear Technologies Hear Back Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-16-2004 05:58 PM
