Old 01-01-2006, 11:04 AM
David Penick David Penick is offline
Default Latency problems with Mini-Me
I just bought a Mini-Me and used it to record vocals for the first time. I was having severe latency problems even at 128 samples, so I had to resort to "low latency monitoring," which I would prefer not to do. Has anyone else experienced these latency issues with a Mini-Me? I'm recording at 48K, 24 bits and am using the Mini-Me as the clock. And I'm using a Focusrite Voicemaster Pro as my main preamp, running my mic into the Focusrite first, then into the Mini-Me. I'm also using "SLC" on the Mini-Me. No other hardware is hooked up to the MIni-Me. The Mini-Me is hooked up via S/PDIF to my 002.
Thanks
3.2 GHz Intel Core i7
Mac mini (2018)
Mac OS Mojave 10.14.6
Pro Tools 2019.10
Avid HD Native Thunderbolt
Avid HD Omni
Old 01-01-2006, 11:57 AM
yoursickstudio yoursickstudio is offline
Default Re: Latency problems with Mini-Me
don't you have an external mix desk ? small one.
if you have a mini-me or not you will always get latency
use a small mixing desk for 2 channels protools return and 2 from the mini-me mini aux ouput
Old 01-01-2006, 12:03 PM
I don't have a small mix desk. Can you recommend one?
Mac mini (2018)
Pro Tools 2019.10
Avid HD Omni
Old 01-01-2006, 12:28 PM
Working at 128 samples shouldn't produce much latency. It should be a few milliseconds (like 6 ms.) Anyway, if Low Latency mode works (I never tried it with an S/PDIF input), what's your objection to that?
Just for latency experiment, have you tried the 002 mic preamp, at 128 samples buffer, with and without Low Latency? Was the latency significantly different from using the S/PDIF input?
Quad 2.5 G5, 4.5G RAM
Old 01-01-2006, 01:13 PM
globaleric globaleric is offline
Are you saying that you're getting MORE latency with the external A/D using the SPDIF input than with the 002's internal preamps / ADC?
If so I'd be interested in a statement from Apogee's tech support...
BTW even 64 samples latency is an issue when recording vocals - it's resulting in a weird "chorus" effect in the performer's headphones not everyone can cope with.
Mac Mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Mojave 10.14.6, PT 2019.12, Waves and Massey plugins
Presonus Quantum, MC Transport, Avid Control, Tascam HS-P82 Field Recorder
Old 01-01-2006, 02:26 PM
When I was using the 002's preamp, I could record at up to 512 samples with no problem. I have more latency with the Mini-Me going through S/PDIF. Low latency monitoring works fine, except it disables plug-ins that are on the record-enabled track, and since I don't usually use plug-ins when I'm recording vocal tracks, it's not that big a deal.
Mac mini (2018)
Pro Tools 2019.10
Avid HD Omni
Old 01-01-2006, 02:29 PM
Yes, I'm getting more latency with the Mini-Me AD than with the 002's internal preamp AD.
Mac mini (2018)
Pro Tools 2019.10
Avid HD Omni
Old 01-01-2006, 03:14 PM
I'd say the vast majority of users here on the DUC would disagree with you on that, most make do just fine without using an external, no-latency mixer setup.
Old 01-01-2006, 03:37 PM
Of course I was meaning a Digi002-only setup without any external mixer!
And I bet the vast majority will hear the latency with such a setup.
Old 01-01-2006, 03:46 PM
your fix with no external mix desk would be:
mini-me -> s/pdif -> digi002
mini-me aux output -> analog -> digi002
that way you can use the low latency monitoring the digi002 offers
same thing can be done with the MBOX2.
mbox mini latency Ericsov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-18-2012 09:03 PM
MBox 2 Mini Mix Latency my808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-06-2007 03:11 AM
MBox2 Mini and Zero Latency? jandue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-10-2007 05:54 PM
mbox + mini me latency issues jvancorduroy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-22-2003 07:08 AM
Help !! Mbox +Mini Me latency issue jvancorduroy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-18-2003 10:38 AM
