#31
Re: Suddenly PT won't load Plug-Ins because not valid 64-bit
I did an Apple security update and now have this issue with some of my non iLok autherized plugins. This is a big deal. 2 effected plugs for me are Sonarworks and Nugen VIslm2. They are critical to my workflow.
I uninstalled and reinstalled plugs/PT and nothing works. Booted from my most recent clone and everything works. Mac Pro 5,1 / 10.12.6 / Ultimate 2019.6 |
#32
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#33
Yes, this is the solution I have heard most often so why not
#34
We have a similar system. How are you finding high Sierra with your Mac Pro? Any issues with the nvidea web driver?
#35
The only issue I've had is with colours but that has to do with colour calibration on the multiple screens -- Xrite hardware calibrated) and the recent version of DADman not liking non-RGB profiles (older versions had no issue.) But I'm working with them and they're interested in fixing this issue (has to do with wide gamut) so temporarily have changed colour profile setups. This (non-RGB) had affected seeing highlighted areas in Pro Tools text entry fields as well. Currently my main edit screen is in RGB mode while my main video picture screen is staying calibrated. The first issue DADman/DAD know about. The second issue is a recent development that could be linked to High Sierra or the nVidia Web Driver (they auto update together.) But nothing I'm really thinking about on the day-to-day since everything works after the colour profile change. My guess is I'm part of a really small subset who would run into this. Apple's general profiles for screens are RGB.
#36
#37
I'd like to chime in on this thread. I'm on El Capitan, with Pro Tools 12.7.1 and experienced the same issue with Sonarworks weeks ago. Sonarworks can't seem to help me out and AVID is claiming this is a IOS 13 thing even though I started seeing the problem weeks earlier. I paid for a service ticket, and no one has even bothered to ask for logs. They just keep on saying this is a known issue. Has anyone reported this problem with OS 10.11.6 ? Upgrading my OS means I also have to upgrade my version of PT forcing to a yearly subscription of PT. All of plugs Waves, UAD, IZotope, work fine, just Sonarworks seems to to be the issue. I typically ignore updates on my OS as Apple has a tendency to cause incompatibilities with already running software.
#38
I have an open tkt with Avid and Sonarworks. Neither seems to truly know what’s going on and the only fix I’ve gotten was to update to High Sierra (which I’d rather not do).
I did the iOS 13 update a week ago with no issues. Did a security update yesterday and got this problem. Unfortunately in my experience when apple breaks something it takes Avid a very long time to fix it (if ever). |
#39
No, you could still use PT 12.7.1 with macOS 10.12.2 (supported) and very likely latest Sierra update as well. In fact I would recommend you take this upgrade when you have time to do so, because ElCrap is notoriously bad version of macOS
#40
Thank you very much for the advise. I think I'll do that tonight.
"Not valid 64 bit AAX plug-ins" - almost all 3rd party plugins suddenly corrupt | noiseboyuk | Pro Tools 2018 | 13 | 10-13-2020 01:14 PM |
falcon failed to load because it is not a valid 64 bit plugin | fourthtunz | Pro Tools 2019 | 1 | 07-09-2019 07:36 AM |
Some UAD plugs "failed to load...not valid 64 bit AAX..." | sfsonarboy | AAX Plug-ins | 3 | 02-04-2016 05:55 PM |
Pro Tools Suddenly takes up to 4 minutes to load | ashm | macOS | 5 | 12-31-2010 04:17 PM |
PT 7.4 Suddenly Does Not Load | Toonvox | Pro Tools TDM Systems (Win) | 7 | 07-15-2009 01:11 AM |
