Old 11-12-2010, 04:30 AM
lennieh lennieh is offline
Default Liquid Mix TDM with Win7????
Anyone tried getting this to work? The installer won't run on Win7,
Focusrite were very unhelpful even when I pointed out the next release of PT would be Win7 only (PT9 it's here now!).
I have a dual boot XP/Win7 machine so I'm thinking I could maybe copy over the files from one partition to the other, track down any registry changes???
Old 11-17-2010, 12:15 PM
avasound avasound is offline
Default Re: Liquid Mix TDM with Win7????
Hi!
I too have Liquid Mix TDM.I asked this question to Focusrite Tech Support. Here their answer:
Unfortunately there is no scheduled plan to release a 64-bit version of the Liquid Mix HD plugin at the current time.
It might be something that is possibly implemented in the future. If you would like to get access to this before it is released then I would advise you to sign up to our beta site:
http://beta.focusrite.com
Sorry that I couldn't be of greater assistance.
Best regards,Joe Noel
Focusrite/Novation Tech Support
Old 11-17-2010, 12:27 PM
Talk about synchronicity, I just this minute got it working
The Emulations install just fine just by runnning the installers.
And I copied over the pluging files from my XP partition to my Win7 x64 partition.
Focusrite are just being lazy, they just need to build a new installer. I only got to speak(email) to support guy, and he just came out with some bull about no plans to support Win 7 but they will review it if it becomes necessary and the dev guys will sort it out when they need to......
Old 11-03-2017, 01:27 AM
maniman's Avatar
maniman maniman is offline
Not true , the plugin works under 32 bits windows 7 the Emulations can be installed anyway they aren't seen by the plug in (the plugin don't populate the list) . Any point ? where need to put the emulations ?
tryng windows 7 32 bits with pro tools 10 hd on hd 2 pci system , evidently all legit software.
If i not find the way I need to stay in pt 8 hd on the g5 , for me no problem but to the customer side is not a great point.
Thank you guys.
Mani.
Old 11-03-2017, 05:34 PM
Neil H Neil H is offline
It does work as mentioned already by installing on a Windows XP PC and then copying the plugin files from there to a Windows 7 32 or 64 bit PC the plugin is TDM only not RTAS so will only appear in PT HD up to version 10. The library does need to be copied to a specific path which is in the focusrite documentation.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 11-16-2017, 01:09 AM
maniman's Avatar
Where please ? The only paths mentioned in the Focusrite documentation are the Snapshots paths
(C:\Users\*username*\Application Data\LiquidMix). If someone have this working in windows 7 can tell please where him/her emulation files are placed ?
*In Win 7 the folder is called AppData instead of Application Data , additionally when I try to save a snapshot the plugin only takes me to the current session folder itself , but insist , the problem is where the emulations need to be placed to make the plugin "see" them , the 1.2 web installer works well under win 7 (32 bits).
Many many thanks.
Old 11-16-2017, 06:08 PM
5 seconds on Google tells me:
C:\Documents and Settings\All Users\Application Data\LiquidMix
https://support.focusrite.com/hc/en-...-web-installer
https://www.sweetwater.com/sweetcare...eb-windows-pc/
Windows 10 Pro
Old 11-18-2017, 03:51 AM
maniman's Avatar
MMM...
Think I'm understanding the problem magnitude , try to clarify for future references.
The main problem to have Liquid Mix HD running in Windows 7 is the evident differences of the folders structure between Windows 7 and Windows XP , the XP path "C:\Documents and Settings\" are replaced with the "C:\Users" in Win 7 , Win 7 can interact with certain XP applications though a junction that "links" one to another , but sadly not the case of the Liquid Mix HD emulations files.
This work in the way the guys described for many reasons. Something essential in the linking of the emulations path occurs when install the plugin that make the 1.2 installation directly in Windows7 can't see the emulation files (even if are placed in the juction that represents "C:\Documents and Settings\All Users\Application Data\LiquidMix") , that make me guess when the plugin is installed in a XP partition (or extra XP hd) and the plugin are moved/copied to the mentioned W7 partition the plugin stay taking the emulations from the XP partition.
I think the problem is the kind of stationary way of linking the paths in the installation time.
I gonna try to do a dummy XP hd that contain the emulations installed and mount in the machine.
I will update the experience in this same post.
Many thanks to everybody.
Old 04-02-2019, 01:47 AM
maniman's Avatar
After months givin a try in my free time moments , I can't find the way to have LiquidMix HD working in Windows 7 / PT 10 HD (PCIX , 1 Core + 1 Process).
The plugin can be installed normally , but I can't make the plug "see" the emulation files , in the old G5 was working correctly even with "no Accel".
I gonna keep the license , hope someone in near future can find the way to make it work in my new system , I love it for mastering colors , a pity can't use it anymore.
Best Regards.
Mani.
Liquid mix 16 AnthonyW Pro Tools TDM Systems (Win) 0 05-04-2010 10:29 AM
Liquid Mix themadarchitect General Discussion 0 02-04-2010 12:37 AM
UAD-1 or Liquid mix??? crazy_ow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-11-2008 03:57 AM
Liquid Mix 2.0 JFK StudioDude Pro Tools TDM Systems (Mac) 1 09-03-2007 03:57 AM
liquid mix dgodzillau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-02-2007 03:49 AM
