Old 08-13-2018, 11:00 AM
EmilILönneberga EmilILönneberga is offline
Default 2018.7 TC/E Trim Tool
Hej,
I often have to compress or expand two or more audio clips from different mics (same source) with the trim tool and digidesign TC/E or now Avid TC/E.
This worked phase-stable with PT 12.5.2
Since I upgraded to 2018.7.0 I have to move the clips onto stereo tracks, otherwise they will be compressed or expanded individually.
Afterwards you can't use them together anymore (phasing).
Is this supposed to be a feature? Is there a way to link mono tracks for that purpose? It was just so easy before, select the clips with shift, trim and done.
Thanks a lot!
Old 08-13-2018, 11:03 AM
amagras amagras is offline
Default Re: 2018.7 TC/E Trim Tool
Have you tried linking selected tracks (ctrl+G) ?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 08-13-2018, 11:09 AM
Like group them? (cmd+g)? I did that. Unfortunately it's still the same..
Edit: I just saw that your on windows, it might be a different short cut for the same thing. Sorry, didn't want to be rude! Thanks for your fast reply!
Old 08-13-2018, 06:46 PM
PMF Media PMF Media is offline
It works fine here, 2 mono tracks - voice - I select both and compress while holding the shift key...
Old 08-13-2018, 09:15 PM
Extreme Mixing Extreme Mixing is offline
Maybe try grouping the regions. That should woik. But it SHOULD work just grouping the tracks.
Steve
Steve Shepherd
Extreme Mixing
Old 08-14-2018, 12:34 AM
Basstian Basstian is offline
hmm. I can not duplicate the issue.
If I duplicate a clip and then consolidate one of the pair. To make sure I have two identical clips with different "source material" then select both and trim them together. They stay perfectly in sync an phase. No issue here.
Mac Pro 3,7 GHz Quad-Core Intel Xeon E5
Mac OS 10.15.7
ProTools Ultimate 2020.11
Video Slave 4.3.477
Old 08-14-2018, 01:16 AM
Indeed, same here. But that is only the case if the clips are identical.
But as soon as I have, let's say a vocal track or voice over, recorded with two different mics, they don't stay in sync on mono tracks. Not as grouped clips and not on grouped tracks.
That worked perfectly fine with 12.5.2 and before. I've been doing this as long as I can remember (PT 5 HD)
Now it only works if I put the clips on a stereo track.
Old 08-14-2018, 04:53 AM
No problem, Group is the word, I don't know why I used Link, I suppose that's what's in my mind when I use it.
Have you tried with a different audio? Maybe is the clips you are trying to compress. Also, go to settings and make sure the default TC/E algorithm hasn't been accidentally changed.
amagrasmusic.com
Old 08-14-2018, 06:35 AM
Tried several clips in different sessions. Tried different algorythms in the system prefs as well.. same result.
Same sessions and clips on another system with PT 12.5.2 work without any issues. This really sucks when it comes to ADR or vocal editing. Pardon my french.
Old 11-06-2018, 08:46 AM
a short update: Not fixed in 2018.10 though it does work with 2018.4..
It's really strange and makes my personal editing much harder. I guess I will stick to 2018.4 hoping for a fix in a later version..
Anyone else missing trim plugin after 2018 upgrade? [solved] ratava911 Pro Tools 2018 4 01-30-2018 06:08 AM
Problems with Grabber Tool & Trim Tool S133 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2008 10:19 PM
trim tool on 7.4.2 ? dendee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2008 09:40 PM
Need help with use of Trim Tool Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-14-2008 10:07 AM
TC/E Trim Tool Mike62858 Pro Tools M-Powered (Win) 0 08-12-2007 05:38 AM
