Old 03-26-2018, 10:46 PM
tomicompu tomicompu is offline
Default Pro Tools LE crashes!
Hey! Im having issues with PT. Im running Windows 7 64-bit with a Mbox2. I installed PT like a year ago, and have been using it without a problem. But a few weeks ago it started crashing while it loads. I had re-installed 3 times, trash prefs, and erased everything (related to Avid) and still cannot even get to the menu without crashing. I will copy the log! If any of you can help me, I would appreciate it.
Tue Mar 27 02:41:33 2018
C:\Program Files (x86)\Digidesign\Pro Tools\ProToolsLE.exe v8.0.0.314
Thread: <NONE>
System exception: Stack overflow occurred at address: 0x10B44157 in module: Guitar Rig 5.dpm
Stacktrace:
0x1062042F : - (Guitar Rig 5.dpm @ 0x105D0000)
0x10627368 : - (Guitar Rig 5.dpm @ 0x105D0000)
0x10629F05 : - (Guitar Rig 5.dpm @ 0x105D0000)
0x105ECEC9 : - (Guitar Rig 5.dpm @ 0x105D0000)
0x10A5B464 : - (Guitar Rig 5.dpm @ 0x105D0000)
0x6210404E : - (DAE.dll @ 0x62000000)
An unknown exception occurred
Stacktrace:
0x1003BBAC : - (CFnd.dll @ 0x10000000)
0x069C20C9 : - (ProTools.dll @ 0x064E0000)
0x00408F38 : - (ProToolsLE.exe @ 0x00400000)
0x0040911C : - (ProToolsLE.exe @ 0x00400000)
0x00404F49 : - (ProToolsLE.exe @ 0x00400000)
0x05889FA9 : - (Unknown @ 0x05880000)
0x0082D5D7 : - (ProToolsLE.exe @ 0x00400000)
Old 03-26-2018, 11:01 PM
Top Jimmy's Avatar
Default Re: Pro Tools LE crashes!
If guitar rig is what's crashing pro tools, I would remove it from the plugins folder.
I would also update to 8.0.5 as almost every previous version of 8 suffered from some serious issues.
James Cadwallader
Old 03-26-2018, 11:05 PM
Top Jimmy's Avatar
http://secure.digidesign.com/service...rticleId=43353
James Cadwallader
Old 03-27-2018, 08:27 AM
The Weed's Avatar
The Weed The Weed is offline
IIRC, I think he'll need the 8.03 full installer (can't tell if that's what he has now), then the 8.05 update.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-27-2018, 12:49 PM
Random thoughts:
Guitar rig(and all amp sim plugins) is a huge resource hog, so 5 instances on a 32-bit system would drag most any computer to its knees.
With windows 7, you need a couple of things in play:
#1-use the right-click>Run as Administrator option when installing PT, or any software/update.
#2-you should have the 8.0.5 updater installed(adhering to rule #1)
#3-right-click on the PT icon and select Properties>Compatibility and check the boxes for "always run this program as admin" and "disable desktop composition"
Pro Tools 12 crashes and crashes... Phantobias Pro Tools 12 12 09-15-2015 11:08 AM
Pro Tools 11.0.3 Crashes ADAPTING macOS 1 12-19-2013 04:06 PM
Pro Tools 10.2 crashes again, and again... alfaholic macOS 7 07-04-2012 08:38 PM
>:( Pro Tools 10.2 CRASHES WHEN..... beto515 Windows 1 06-09-2012 05:29 PM
Mac OS X 10.6.2 crashes with Pro Tools 8 NikoNewYork 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-06-2010 11:40 AM
