Old 02-23-2011, 11:48 AM
Pete@twenty7pix Pete@twenty7pix is offline
Default D-Control output calibration for film...
I have two films I'm working on and want to make sure I have the right calibration techniques going on. I have pink noise @ -20dbfs and will place into PT7. The master bus will be going out of the main output from the monitor section of the ICON. I am not sure if both input and output trims should be calibrated to +4dbu (default I think) and from there adjust my amp levels to reach a level of 81 db SPL (these are theatrical releases.) Kind of new at this so any info or direction would be helpful. Thanks all.
Old 02-24-2011, 09:34 AM
lexaudio lexaudio is offline
Default Re: D-Control output calibration for film...
Make sure you are using pink noise from somewhere other then generated from PT.
The pink out of there is wrong and down about 5dB.
Is this a small room? Is that why you are setting it at 81 SPL?
Old 02-28-2011, 10:10 PM
Yes, quite a small room. And I was recommended to try even lower number (close to 72 db). So far, so good. No complaints yet.
NEW UPDATED Room Calibration for Film and TV Post dr sound Post - Surround - Video 314 04-19-2024 01:44 PM
Hearing clipping in mix output. Calibration issue? monkeyhouse macOS 1 01-18-2013 10:28 PM
192 Output Calibration w/ PreSonus Monitor Station TMHearne Pro Tools TDM Systems (Mac) 15 11-29-2010 02:16 PM
Mackie Unversal Control LCD / Fader Calibration Barry Johns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-12-2006 10:17 PM
96 I/O Output Calibration roberts Pro Tools TDM Systems (Mac) 1 07-03-2003 05:01 PM
