Old 12-08-2003, 10:36 AM
besmusic besmusic is offline
Default Please help! FW400 vs FW800 external / Lacie vs..
I've been having constant 6086, 6093, 6097 errors, mostly telling me to increase or decrease H/W buffer in the playback engine on my G5 dual 2.0. w/ 2 gigs RAM.
I saw a post on DUC about these errors, where the advise was to get an Adaptec PCI card to handle the FW hard drive. If I'm having all of these 6086 and 6093 errors, and losing communication with the 002rack, would moving from a FW400 external drive to a FW800 external drive resolve this issue vs getting an Adaptec PCI FW card for the external drive? My thought is instead of putting $50 into a PCI card, I'd put it into a faster external drive, hoping that the FW800 drive is on a seperate bus from the 002rack. Any advice for a very frustrated newbie?
Also, any advice on FW800 vs FW400 fro PT LE 6.2.2? Will FW800 work? Digi won't say they support it, but I know the readers/contributors of the DUC will know the reality. Any thoughts on a Lacie drive vs OCW?
Thanks in advance!
Pete
Pete Turok
Powermac G5 dual 2.0 & Dell i8600
PTLE 6.2.2, 002r
Old 12-08-2003, 04:39 PM
mznyc mznyc is offline
Default Re: Please help! FW400 vs FW800 external / Lacie vs..
Bump
Old 12-11-2003, 12:11 PM
Default FW400 vs FW800 please help
Does FW800 work okay with PT LE 6.2.2 running on a G5? I'm hoping to spend the extra money on a 800 external drive vs a FW400 PCI card, which seems to be the solution for all the errors I've been getting on my G5 where apparantly the two FW400 ports are on a shared bus...please let me know if you're using a FW800 drive with success or problems, as Digi will not talk about them accept that they're testing them..
Thanks
Pete
Pete Turok
PTLE 6.2.2, 002r
Mbox Pro and FW400/FW800 external HD and more... Zakazastar FireWire & USB Audio Interfaces (Mac) 2 07-30-2013 06:27 AM
Recurring Problem with Lacie D2 Quadra Firewire. Daisy chaining FW400 and FW800? MOGAZI Storage Subsystems 4 08-14-2009 04:05 AM
External HDD Test - FW400 vs. FW800 vs. eSATA DJerry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-2008 10:36 AM
FW400 with FW800 lancejorton Pro Tools TDM Systems (Mac) 12 05-08-2004 11:52 AM
OT:Can u daisy chain FW800 and FW400 external HDs? Alex Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2003 09:27 PM
