Old 01-16-2024, 12:52 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Default Re: 2023.12.1 official download archive is corrupted!
Link just worked perfectly for me.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 01-16-2024, 01:05 PM
atticmike atticmike is offline
The Link itself works fine but the archive is corrupted, both on my products and avid download center, it's the same file.
Try to unpack it and you'll see.
Old 01-16-2024, 01:07 PM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by atticmike View Post
Should I write the support a ticket?
If you cannot solve your problem with self-help, then yes.
Janne
Old 01-16-2024, 01:08 PM
Can't, Avid uploaded a corrupt install archive.
Old 01-16-2024, 01:40 PM
cvicente22's Avatar
cvicente22 cvicente22 is offline
Hello folks - I've also coordinated this with our developers to have this fixed ASAP. Thank you for bringing this to our attention.
Regards,
Charles
________________
To create an Avid Support Case, you may go to https://www.avid.com/learn-and-support/contact-audio-and-music-support
  #16
Old 01-16-2024, 01:56 PM
Link installed mine in windows 10.
Interview
  #17
Old 01-16-2024, 02:26 PM
Thanks a lot 🙏 Can you let us know once it's fixed?
Avid Link works fine because I don't think it uses a .zip archive as a source or maybe a different one then. I'm not using Avid Link anymore though ever since Lofi was missing when I installed Pro Tools through it and some other stock plugins.
  #18
Old 01-16-2024, 03:26 PM
For me Windows 11 reports the zip file as empty or some other problem that it can't unzip/show contents.
FWIW the files Pro_Tools_2023.12.1_Win.zip downloaded from My Products or the Download Center are identical. And the size and MD5 hash match what is reported on Download Center (e.g. verified with certutil).
Mac does unzip the files OK (so you could unzip there and move the folder over to Windows if you have a Mac). Windows zip can be a bit fussy, but these are old Zip 2 compatible files, so at least on the surface nothing close to exotic.
So not sure why some others don't see problems, maybe they are using third party zip utilities, but glad Charles has Avid folks looking at it.
I thought Avid Link uses the zip files... and maybe it has an internal unzip different from Windows, but I don't know and I ain't installing that bloatware to check. :-O
  #19
Old 01-16-2024, 05:04 PM
What are the chances that they might zip the Windows Installer in Mac OS ��
It's not empty for me but when I try to unpack it I get straight a hard-error.
I remember returning to Pro Tools when Avid Link became a thing so I installed Pro Tools with it and couldn't make sense as to why Lofi and other stock plugins were missing and in the end people had a similar experience and told me to avoid Avid Link to install Pro Tools. At first I thought the plugins come now with a separate installer because they aren't included anymore but nope it was Avid Link.
  #20
Old 01-16-2024, 06:36 PM
cvicente22's Avatar
Hello Folks - just fyi, this issue is being covered under LRE-10286. We will get back to you asap. We apologize about the inconvenience.
Regards,
Charles
________________
Troubles with a corrupted session [solved] bluesguy76 Pro Tools 12 3 11-09-2015 06:52 AM
Eleven 10.3.3 Win download is corrupted ChazC AAX Plug-ins 4 12-20-2012 07:19 PM
Can't find official download link for Pro Tools 9 dietermoreno Pro Tools 9 1 08-23-2012 03:59 AM
MPTK2 download corrupted djblah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 02-05-2009 06:02 PM
New WAV files corrupted? - SOLVED Bill0287 Pro Tools M-Powered (Win) 1 03-12-2006 07:23 PM
