Old 10-06-2023, 05:29 AM
blangstrup blangstrup is offline
Default Crash after offline bounce
Pro Tools 2023-2023.9. Windows 10.
After bouncing offline, Pro Tools crashes, becomes unresponsive, I have to force-quit.
Yes, I have completely reinstalled windows, absolutely NO plugins installed, and still Pro Tools crashes after offline bounce. It also happens when bouncing from midi to an audio track. Online bouncing is good, also commit clip to audio.
It's very annoying.
TIA!
And yes, I have tried searching for a thread about this, and couldn't find any, not new, anyways, but maybe I don't know how to search. I am sure somebody will mock me and ask me to google etcetera, but...
Old 10-06-2023, 06:34 PM
sw rec sw rec is online now
Default Re: Crash after offline bounce
System info, please.
https://duc.avid.com/showthread.php?t=300050
Old 10-06-2023, 06:39 PM
And what do you mean by "no plugins installed".
Do you mean
1. You removed all the .aaxplugin files from the plugin folder?
2. You don't have any plugins instantiated in the session (placed in inserts)
3. You never installed any additional Avid plugins? Or any additional third party plugins on your system?
Only #1 is the solid test of plugin issues, follow the standard troubleshooting steps to temp. remove all .aaxplugin files and see if the problem goes away, put them back in batches trying to find the plugin(s) that might be causing problems. But as always start troubleshooting with trashing prefs.
Old 10-07-2023, 02:34 AM
... as I said, I completely wiped the pc/reinstalled windows 10, and NOTHING ELSE! Then installed Pro Tools 2023.9 and still it crashed bouncing.
(I have seen all the other threads where the only advice was reinstalling one plugin after another, checking).
Device name Huckleberry
Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz
Installed RAM 16,0 GB
System type 64-bit operating system, x64-based processor
Edition Windows 10 Pro
Version 22H2
Installed on ‎19-‎09-‎2023
OS build 19045.3448
Experience Windows Feature Experience Pack 1000.19044.1000.0
Old 01-22-2024, 02:01 PM
hackboys hackboys is offline
By any chance, what interface are you using? I'm having the same issue with a MOTU M4
Old 02-28-2024, 02:49 AM
Motu M4
Assistance with HDX DSP Offline Bounce Crash fsavell Pro Tools HDX & HD Native Systems (Mac) 9 09-10-2023 01:51 AM
Offline Bounce vs Realtime Bounce vs Recorded-in-Session - BIG differences in PT2021 andresix Pro Tools 13 11-19-2021 07:03 PM
Pro Tools 2021.6 crash / freeze after offline bounce innerbooty Pro Tools 5 09-13-2021 12:16 PM
Offline bounce - session file backup - crash simonchase Pro Tools 11 0 04-23-2015 10:08 AM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
