Old 01-27-2019, 11:15 PM
larsongs larsongs is offline
Default Won't create Session from Template?
Running PT10, MBP, Glyph External HD, PResonus 16.4.2....
I'm currently running & using PT10. But, I recently purchased PT2018 & registered it with ILok & PT.. I haven't upgraded to it yet. For later use when I upgrade my MBP or get a new IMac...
Using my current PT10 I'm unable to create a New Session from one of my Templates? Any ideas or suggestions?
Trying to create new Session but get a message that says,
Could not complete the open Session Command because you don't have appropriate access priveliged (-5000) while creating Larson Brothers Album 2
Old 01-28-2019, 08:39 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Won't create Session from Template?
This could be to do with disk permissions on the hard drive or folder where your template is.
Go to the folder and drive and check disk permissions. Right click> get info> sharing and permissions. Click the lock logo bottom right to un-lock then you can change all permissions for system / admin / user/ everyone etc to "read & write"
see if that works
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-29-2019, 10:40 PM
Thanks, that was it....
Create session from template prob - PT12.7, Mac OS Sierra. oscar4072 Pro Tools 12 2 02-07-2017 08:34 AM
How do you create a Session template ? kt90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-13-2009 02:05 PM
How do I create a Mix or Session Template? dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-17-2008 05:38 AM
How do you create a session template in protools7? JAKE @ LOUD Pro Tools TDM Systems (Mac) 3 06-24-2006 08:43 AM
How to create a "template" session ? David Every 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-12-2005 07:53 PM
