Old 12-21-2018, 03:52 AM
klil klil is offline
Default AAF video track problem - video stretched
Hi everybody, i need Help Please.
When i import an AAF session to protools 10, the Video track is stretched and being longer than the audio material. It's an AAF coming from Adobe premiere 2017. Everything is ok with the frame rate, it's 23,9 in both protools and Premiere.
did someone had this issue before ?
Any tips/trick to get this working ?
Thaks
Old 01-21-2019, 11:38 AM
Lightbulb Re: AAF video track problem - video stretched
That is the problem (Adobe Premiere).
That is good, though the problem is still likely to be that Adobe Premiere is the source application.
I have had issues with AAFs from Adobe Premiere before.
Ask the editor to export the video separately from the AAF in an .mov container. Import the audio from the AAF and import the video from the separate export.
Video output resolutions greyed out on video track Syrcular Pro Tools 11 1 08-08-2013 07:34 AM
QT video, problem importing audio track CLee Post - Surround - Video 1 09-06-2012 12:05 PM
A problem occurred while trying to update the video track Reckless Erik Post - Surround - Video 2 11-09-2010 06:54 AM
Avid video disappears in video track deardaddy Post - Surround - Video 0 10-31-2006 01:03 AM
Video Track/Quicktime Problem in 7.2 zeeman Pro Tools TDM Systems (Mac) 4 08-08-2006 01:15 PM
