Old 06-30-2016, 05:37 PM
polyh3dron polyh3dron is offline
Default S6 not recognizing any modules, including master module
EDIT: big brain fart. all fixed.
Old 06-30-2016, 05:50 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Default Re: S6 not recognizing any modules, including master module
Which ethernet port on the MTM is connected to the switch? Port 2 is the go.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 06-30-2016, 05:55 PM
OK, I figured it out.. Misread the instructions.. Everything goes to the switch and then a cable from the switch goes to the computer, that's what I need to do.
Old 06-30-2016, 06:06 PM
Buccanears's Avatar
Change it up. Connect Port 2 on the MTM to the S6 internal switch. Then from the internal switch, run that out to your computer or external switch.
Sounds as though the MTM is not seeing the rest of the networked modules.
IMDB
Old 06-30-2016, 06:14 PM
Buccanears's Avatar
Yup
IMDB
Master Module FAN NOISE rcutz Avid S4/S6 11 07-29-2015 06:39 AM
Setting up Master Keyboard with Modules BTyler1230 Pro Tools 11 2 04-02-2014 05:51 AM
Hd 10 including ilok vin7 Buy & Sell 2 03-23-2013 12:37 PM
10.3 upgrade including IEP Righty27 macOS 4 09-22-2012 04:50 AM
2 Problems: PT not recognizing plug-in and CPU not recognizing external hard drives jasonguitar Pro Tools M-Powered (Win) 0 06-28-2009 06:32 AM
