Master Module FAN NOISE
Hi guys, my MM start to give me some fan noise. My room is all ways set to 22º Celsius. My MM also has start to freeze, without responding to any touch or buttom. It only works againa after a 're-start'. There is some troubleshooting I should do. Still 1.4 here.
Ricardo Cutz Re-recording mixer/sound editor supervisor. Http://106db.com.br ----- |
Re: Master Module FAN NOISE
I can't comment on the freeze, but the fan running was a issue a few of us had at one point. Logging out and logging back in to the user account (not turning in and off) gets rid of the problem.
After a few times, mine stopped doing it altogether. |
Haven't tried it myself, but a friend of mine told me there's no fan noise if you shut down via software (settings>about>shut down), instead of button. I'm on 2.0 and there's no noise at all.
rcutz, I would reinstall the software to see if freezes continue after that. |
The fan issue was fixed in v1.4. The Master Module App controls the fan so if its crashing/not running that could explain it. Are you definitely sure its the fan, there is some heat pipe noise sometimes but that's a different sound to a fan running.
Can you also check the temp of the MM CPU, if it goes above 85 then the fan would come on...maybe explain the freeze too. (Go to the surface page and touch the image of the MM, you should see the temp of the Window CPU as well as the module CPU) |
Eddie, I switched to 2.0 couple of days ago. I was on 1.4 before that and the fan noise was there, temp fix being log out / log in procedure.
I had a MM freeze, where the touch display and entire surface became unresponsive while I was working, with no particular cause. Happened shortly after installing 2.0, I think the day after. I experienced one instance where the system booted and only partially connected to PT12. MM was unresponsive and its softkey displays remained blank while automation module softkey displays appeared and fader modules popped up to track values. Restart of PT and S6 resolved trouble. Otherwise S6 has been solid.
Fan noise, not since installing 1.4. |
I`m in a tight schedulle mixing like hell. What do you suggest: 1- Re-install 1.4 2- Goes to 2.0 (remembering I`m at 11.3.1) 3- Live with those issues until the mix is done? @branko I all ways shut down throug the software. I only do the "hard" shutdown in this freeze situation best
Personally, I would reinstall 1.4. Maybe you'll be lucky and it will solve problem. I don't think you'll have to reset prefs or anything. I wouldn't install 2 yet because of a few differences in operation. No reason to switch until time to experiment with the changes. |
It's strange. We have two S6 controllers and one still have the fan noise issue, although both has been updated to the 1.4. Maybe 2.0 will solve the other S6 too.
my blog:Tamas Dragon |
White noise while loding, no playback, and master fader constantly on FULL, HELP! | flowetic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-03-2011 05:36 PM |
Help, short noise every 2 seconds in the master channel | noblejeanz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-01-2009 11:16 AM |
Master fader & L3 inducing noise | Camilo Toledo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-20-2006 08:22 AM |
Attn: Drumkit from Hell experts: noise noise noise | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-30-2003 06:31 AM |
Digital noise out master fader, 1622 | sidereal | Pro Tools TDM Systems (Mac) | 9 | 07-16-2001 07:53 AM |
