Old 03-24-2012, 09:33 PM
STL Audio STL Audio is offline
Default Dual Boot 10.6 running 8HD & 10.7 running 10HD
Hi all,
I couldn't seem to find this info so I thought I'd ask away....
I am currently running 10.6.8 with 8HD in a commercial studio with bookings everyday.
I want to move to 10HD and purchased the upgrade. But before I go for it I wanted to clarify two things.
I have 10.7 on a new drive that I used migration assistant to pull my 10.6 info off and I want to upgrade 10 on that and boot between the two while I get used 10.7 and 10HD. I know that 10 is a different PTHD file so I am aware of that aspect.
My questions are:
1. If I upgrade my 8HD license to 10 HD will my ilok will I still be able to boot 8HD up on the 10.6 system?
2. Is the migrate assistant a bad idea?
Thanks in advance to all.
TKO - STL Audio.
Old 03-25-2012, 08:52 AM
ggegan ggegan is offline
Default Re: Dual Boot 10.6 running 8HD & 10.7 running 10HD
You will probably be required to surrender your PT8 license when you upgrade. However, you may have a backup license for PT8 on your iLok. If so, I would move it to another iLok before you upgrade so you can still use it, even though you have surrendered the primary license.
The way I approached having two bootable partitions was to use Carbon Copy Cloner to make a block level clone of my 10.6.8 system drive on an external drive. Then I partitioned one of my other internal drives and block level cloned the external drive to the new partition. Then I upgraded one of the systems to Lion and PT10. This way both the Snow Leopard and the Lion partitions are as identical as possible. I don't think the Migration Assistant is necessarily a bad idea, but I don't know exactly which files it transfers and which it doesn't, so I felt that working with block level clones was the most predictable approach.
You can make the cloned partition on the original system drive in a single step if you want, but it won't be a block level clone because you have to be able to unmount both the source drive and the destination drive for a block level clone. There probably won't be any issues if you don't do a block level clone, but I felt that a block level clone on a separate drive was a safer approach, plus you have a bootable backup of the original system drive on the external drive in case anything goes wrong.
Gary Gegan
Old 03-25-2012, 11:59 AM
Thanks Gary.
I'll make a copy of the ilok!
TKO
Old 04-14-2012, 05:38 AM
Hey Guys,
So from a fresh 10.7 I used migrate assistant to pull my data from 10.6. I install PTHD 10 and for the first week it was amazing. Now for no reason it just crashes every 3-5 mins. No beach ball just a crash and log. I has crashed on one session now so many time the PT file is corrupt and won't open.
I have booted back into my 10.6 drive after 'Saving As' the albums songs I am currently working on into PTHD8 files so I can run stable and its fine.
Should I :
A. Just build from scratch my 10.7 with no migrate and see how I go?
B. Try some ideas on the 10.7?
C. Take my 10.6 re clone and upgrade that to PTHD 10. I only moved to 10 because I was under the impression you had to.
I am running :
Brand New 8 Core Mac Pro
4GB Stock Ram and 16GB upgraded
Magma expansion chassis
Any help is appreciated.
TKO - STL Audio.
Problem with running Pro tools 7.4 le in BOOT CAMP. michealk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-10-2008 08:19 AM
MacBook with Leopard running XP in Boot-camp compatibility SosNY Pro Tools M-Powered (Mac) 0 12-10-2007 07:16 PM
Running Pro Tools on Mac with Boot Camp... Robbie Hollywood Pro Tools M-Powered (Win) 1 11-12-2007 12:07 AM
Anybody with a G4 dual 1.25 running PT7? mixboy bob Pro Tools TDM Systems (Mac) 6 12-14-2005 07:05 AM
DAE issues running PT 5.1 with dual boot 466 G4 ericmiles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-27-2005 12:21 PM
