Mbox 2 Not Turning On
I just recently built a new computer for home recording/life purposes, since my old laptop doesn't quite have the juice for much editing or mixing. I've been running my Pro Tools 8 LE on my laptop decently well for tracking and such on Vista Business 32 bit, but when I tried to install PT8LE on my new computer, the mbox stopped turning on...even on the laptop on which it was previously working. Here are the specs:
OS: Windows 7 enterprise 64 bit Processor: Intel i5 2500K sandybridge Motherboard: AsusP8Z68-V PRO LGA 1155 Intel Z68 RAM: G.SKILL Ripjaws X Series 8GB HDD: Seagate Momentus XT 500GB 7200 RPM 32MB Looking at previous forum posts, I was able to find that people had problems running PT8 without the .0.5 update, so I updated on both computers. The usb light still won't turn on. I also tried a new cable....didn't turn on. My last thought is that there might be a multiple license issue. But even then, the mbox2 should still turn on...right? Any and all help would be much appreciated! |
Re: Mbox 2 Not Turning On
Didn't realize I needed a sandra report, so here it is:
Processor Model : Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Speed : 3.61GHz Cores per Processor : 4 Unit(s) Type : Quad-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS P8Z68-V PRO BIOS : AMI (OEM) 0706 08/05/2011 Bus(es) : X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 8GB DIMM DDR3 Chipset Model : ASUS Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 800MHz (1.6GHz) Memory Module(s) Memory Module : G.Skill F3-12800CL8-4GBXM 4GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : G.Skill F3-12800CL8-4GBXM 4GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) Video System Video Adapter : NVIDIA GeForce 8400GS (16 SM4.1 1.24GHz, 1GB DDR3 1.2GHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 8400GS (8SP 1C 1.24GHz, 1GB DDR3 1.2GHz 128-bit) Compute Shader Processor : NVIDIA GeForce 8400GS (16SP 1.24GHz, 1GB DDR3 1.2GHz 128-bit) CUDA GP Processor : NVIDIA GeForce 8400GS (8SP 1C 1.24GHz, 1GB DDR3 1.2GHz 128-bit) Storage Devices Seagate ST95005620AS (500.1GB, SATA300, 2.5", 7200rpm) : 466GB (C:) Seagate ST2000DL001-9VT156 (2TB, USB/SATA300, 5900rpm) : 2TB (E:) ASUS DRW-24B1ST a (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices System Reserved : 100MB (NTFS) FreeAgent GoFlex Drive (E:) : 2TB (NTFS) @ Seagate ST2000DL001-9VT156 (2TB, USB/SATA300, 5900rpm) Hard Disk (C:) : 466GB (NTFS) @ Seagate ST95005620AS (500.1GB, SATA300, 2.5", 7200rpm) Optical Drive (D:) : N/A @ ASUS DRW-24B1ST a (SATA150, DVD+-RW, CD-RW, 2MB Cache) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Its possible(and I hope true) that the install was done incorrectly for your setup(Win 7 64 bit). Disconnect the Mbox and run the uninstaller that is on the PT8 disk. Next, download and install Quicktime(if you have not done it already, and download the 8.0.5 updater and drop it somewhere handy(like the desktop). Now run the PT8 installer and when the installer tells you to "connect the interface", DON'T connect the Mbox. Just click on okay and let it finish and reboot. Now run the 8.0.5 updater. Here is where there are conflicting opinions. Some say to connect the Mbox when the updater asks for it, and some say don't(for me, connecting worked with my 003). In either case, let the updater complete and reboot(connect the Mbox if you haven't done it during the update install). Cross your fingers and try running PT(have your authorization code handy too. The one that starts with "DIGI08.......").
BTW, that Seagate 2TB drive is NOT a good recording drive as its a 5900 rpm drive and you need 7200 rpm. Your best route there is to install another internal drive(WD Caviar Black would be my first choice) Your RAM looks to be on the slow side(not sure if it matters). Timings on my rigs are either 7-7-7-20(rig below) or 9-9-9-24 on my new i5. Another BTW, don't forget to perform ALL the system tweaks, especially turning OFF the Aero feature and power management for all USB ports(aka "Root Hub" in Device Manager).
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix BTW, my name is Dave, but most people call me.........................Dave Last edited by albee1952; 11-04-2011 at 12:50 PM. Reason: more stuff |
Thank you for the reply albee1952!
Unfortunately...no success with either method. Uninstalled, ran the install by plugging in the mbox2 when it directed during the 8.0.5 update. The USB light never turned on, and when I tried to open Pro Tools, the hardware was not recognized. Uninstalled again, ran the full install and 8.0.5 update without plugging in the mbox2 until everything was installed/restarted, and again the USB light never turned on, and no hardware was recognized when I tried to fire up pro tools. I know that the USB ports are working, since I tested the power of them with a thumb drive and my usb mouse and keyboard combo, with which I'm typing right now. Since this probably means that there's a hardware problem...what next? Should I simply give up on pro tools 8? And if I were to switch to either 9 or 10, would the pro tools 8 files be compatible/openable? Or is there another fix that is escaping me? Thanks again for any help. |
Mbox 3 Pro not turning on. Dead? | ripsta415 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-17-2012 05:20 PM |
Caveman needs help turning on Mbox 2. | Rain City Rock | Tips & Tricks | 5 | 03-18-2011 05:01 AM |
mbox hardware not turning on | AStabbinHobo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-27-2006 12:47 PM |
Mbox 2 not 'turning on' with Mac Book pro | atinyspeckofdust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-24-2006 06:16 PM |
help turning my mbox into a sound card. | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2003 11:54 AM |
