Old 04-15-2011, 08:05 PM
macdog macdog is offline
Default Edit Window Cursor Not In Sync
Hi
At work we're running a 48 channel HD2 192 + sync rig on a Quad Core Xeon 3Ghz with 4Gb RAM with ATI Radeon HD2600 256Mb. Currently Mac OS 10.6.6 and HD 8.1.1
We have a problem that I first noticed when we upgraded from 8.03 to 8.04 (I cant remember what OS but it might have been a move to Snow Leopard).
The problem is when occasionally playing back and recording the edit window display is not in sync with audio. Playback and recording is not affected and it can sort of be cured by zooming in the out again. I've tried all the usual, followed protocols when upgrading etc but I'm not the only user.
I thought it could be down to a Keyspan serial adapter (V2.6 syncing to SSL9000J) but I've unplugged and disabled it. There are no obvious issues in console and I'm completely stuck...
Any ideas? I've had a good search here and not found any relevant posts
TIA
Simon
Old 04-18-2011, 04:21 PM
Default Re: Edit Window Cursor Not In Sync
Anybody any thoughts on this? Avid support?
Old 04-24-2011, 02:21 PM
Micks_Mix Micks_Mix is offline
Hi, I had the same problem. The reason was that ADC was active, and at least one track exceeded the maximum delay that could be compensated.
Solution: Set your Delay Compensation Engine to "Long" and watch the delays in your mix windows (avoid them to be red).
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave
Old 04-27-2011, 07:57 AM
Hi, thanks for posting. I have adc off when recording and when mixing have it on short as I only use a few compressor plugins. We normally always have quick punch enabled when tracking, disabling improves the situation. I'll investigate long ADC to see if the playback issue gets better...
Cheers
Simon
Old 08-11-2011, 05:52 AM
Any news on this?
The biggest problem is that the automation data is also out of sync in this case... I never saw this behavior in PT 5.1, before I upgraded to HD 8.0.
Anyone else with this problem? Any suggestions to solve this?
Old 08-11-2011, 01:02 PM
FajitaTone FajitaTone is offline
are any of the tracks elastic?
processing of elastic tracks in real time takes up resources.
Ray Trujillo
Freelance Audio Engineer
Old 08-11-2011, 01:12 PM
no.
but is it true that automation data is not considered by ADC?
So that might be the reason... I read this in another thread.
I will test this.
Edit window follow the cursor? D.Orlando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-17-2007 02:55 PM
Cursor ghost in edit window James A. Abdo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-21-2006 08:54 AM
Edit window grabs cursor ?? syMPh Pro Tools TDM Systems (Mac) 11 08-21-2006 07:52 AM
Protools Edit Window Cursor on OSX grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-31-2004 02:39 PM
Cursor Trouble in Edit Window norton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2003 07:29 AM
