Zap every 10 seconds from 96 i/o
hey folks,
I just hooked up a 96 i/o to my 192 to run an 1176 and a couple external pres into. but now if I set anything up as an insert, or select a pre as an input, I get a loud zap about every 10 seconds. strangely, about every 5 seconds with the insert, and 10 seconds with the inputs). any ideas?? |
Re: Zap every 10 seconds from 96 i/o
How is it being clocked? And i'm guessing you means in pro tools, not from the actual box itself... because if the box is zapping TURN IT OFF! :P
Both devices are set to internal, just connected by a digilink cable.
and yes, getting zaps through pro tools outputs. |
YES! Thank you!
30 seconds???? | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-12-2010 01:44 AM |
record for a few seconds | mrsohl | Pro Tools M-Powered (Win) | 1 | 01-14-2010 12:17 PM |
cut out 4 seconds - now I have a click | sambeau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-29-2008 04:32 PM |
8 Seconds To Record? | DrewDrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-16-2007 06:00 AM |
Only when I select a few seconds... | nate the great | Pro Tools TDM Systems (Mac) | 2 | 06-23-2003 10:45 AM |
