Old 05-30-2010, 08:19 PM
JRup JRup is offline
Default Running Pro Tools LE 8 on XP and running 2 monitors
Has anyone set up their protools where they are running on 2 screens this way they can have the edit window on one screen and the mix window on the other? just installed my 2nd monitor ( and new video card of course ) and got the 2 monitors working in XP but now looking fro some help on trying to configure protools for 2 monitors - any suggestions?
Old 05-30-2010, 08:30 PM
rqstudio rqstudio is offline
Default Re: Running Pro Tools LE 8 on XP and running 2 monitors
Maybe just set up a session the way you like it and save it as a Template.
www.rickqueststudio.com
Old 05-30-2010, 08:32 PM
cwsand's Avatar
cwsand cwsand is offline
Set up a session the way you want it and hit Alt + F4 to exit PT. Then when you reload PT and open another session, your windows configuration should be saved.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-30-2010, 08:56 PM
sw rec sw rec is offline
What you need to do when you first open Pro Tools is to resize the PARENT window across both monitors, then open a session, put the edit & mix windows where you want them, and then as described above, close with alt-f4.
Doing this with THREE monitors (mix-edit-plugin or video) and it remembers every window position every time.
http://www.southwestrecording.com/do...t/STUDIO-2.JPG
Old 05-30-2010, 09:31 PM
Benoni's Avatar
Benoni Benoni is offline
Two screens is the way to go man, minimum. Im considering expanding to 3 or 4.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-31-2010, 12:50 AM
gjohung gjohung is offline
This is my 2 monitor setup
http://gallery.me.com/gjohung/100166...12752920950001
http://gallery.me.com/gjohung/100166...12752920920001
http://gallery.me.com/gjohung/100166...12752920970001
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB
ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49
Old 05-31-2010, 02:12 AM
TOM@METRO's Avatar
I run 3 screens at the console and duplicate 2 of them at the MIDI station, and all is well.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-31-2010, 03:54 AM
OK so thats my question - how do you go in and resize this stuff - thats the part i need to help get myself going on this this is the first time i am ever using a 2 monitor setup so i am sort of new at that end of things - i am quite coputer literate but this is a little different for me.
thanks everyone for their info - i am sure it will help a ton.
Old 05-31-2010, 04:43 AM
i GOT IT !!
THANKS A TON!!!!!!!!!!!!!!!!!
Old 05-31-2010, 04:50 AM
Mork_ Mork_ is offline
Drag the main PT window to fill both monitors, restore down the arrange window and drag the corners to fill the left monitor, restore down the mix window, drag it across to the right monitor then drag the corners to fit the monitor. I also have the transport control on the bottom of the right monitor. Now close with Alt f4. Open PT again and it should be saved.
(restore down would be the middle icon of the three on the extreme top right of your screen...)
Running Two Size Monitors on Mac Pro wdjudd General Discussion 5 07-31-2009 09:19 AM
running two monitors dogselur Pro Tools M-Powered (Win) 6 10-10-2006 04:49 PM
How run keyboard through monitors w/o running PT? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-30-2006 06:31 PM
Running passive monitors with 002 WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-27-2005 09:05 PM
Running 2 monitors with PTLE?? voxpitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 03-08-2002 10:44 AM
