Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 12-26-2009, 11:42 AM
zv yoda zv yoda is offline
Default Kick is triggering multiple samples
Hi folks... went out to studio today & this started to happen... when I play the kick, it triggers not only the kick, but also the snare/hats/crashes too... seems to be triggering each of them in sequence.
Any ideas what's causing this?
See sig for my set up - any help greatly appreciated - thanks!
My music
Hardware
21.5" iMac 2.5GHz i5 24Gb (mid 2011), 003 rack, Roland TD12KV, Command8, Axiom 61,
Maxtor OneTouch4 FW/750Gb/16Mb/7200rpm (audio/session drive)
WD 1TB MyBook Studio (backup)
Software
OSX 10.13.6,
PT2018.12.0
Old 12-26-2009, 02:13 PM
Default Re: Kick is triggering multiple samples
I'm using a TD12 triggering Superior Drummer 2 in Pro Tools LE on an iMac.
My music
Hardware
Software
OSX 10.13.6,
PT2018.12.0
Old 12-26-2009, 08:07 PM
Do I understand this right? Each time you hit the kick trigger, you get a different sound? Or it triggers several sounds at once? If its the first, I am baffled(check the midi note assignment in the TD brain for each pad). If its the latter, maybe you need to make the pads less sensitive. I use a TD10 setup and it works extremely well. If I play it, I sometimes need to replace a crash with a choked crash(can't make the VI choke cymbals). If I hire a drummer, I usually have them put up real cymbals and hat and run 3 mics. That works really well, maintains all the nuance of things like the ride and hat, adds some "air" to the overall kit sound, and editing is still fairly easy using Elastic Audio by grouping the mic tracks first.
Old 12-26-2009, 10:42 PM
Crosstalk - either adjust the crosstalk & masking settings in your ekit head or physically isolate the pads mechanically.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-27-2009, 10:37 AM
Actually, it was doing both... I found out what happened.. seems like one of my kids may have changed the settings on the TD12 - it was in the "Jam" setting (where hitting the cymbals starts a bass guiatr riff/synths).
All sorted now
My music
Hardware
Software
OSX 10.13.6,
PT2018.12.0
Old 12-27-2009, 12:18 PM
YOu forgot the anti-kid plugin
Old 01-08-2010, 07:30 AM
Andy666 Andy666 is offline
LOL all over the place
Check out my bands:
NERVE
Death Penalty
Need Triggering Plug-In For Kick Drum MetalDrummer13 Pro Tools M-Powered (Win) 1 04-01-2011 10:58 PM
Need Triggering Plug-In For Kick Drum MetalDrummer13 General Discussion 9 03-17-2011 05:44 PM
triggering a sine wave tone with a kick drum track Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-14-2004 02:01 AM
triggering samples in reason from PT LE Adrian D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-12-2003 06:02 AM
Triggering Kick and Snare in PT Using midi makerthemaker Pro Tools TDM Systems (Mac) 4 10-25-2000 10:26 AM
