Problem Importing More Than One Audio Track
I'm having a problem where I can't import more than one audio track at a time via the import dialog without getting an error:
'Unknown error when selecting xxx.wav' I can drag & drop as many tracks as I like from the Finder, and I can import tracks one at a time from inside the dialog. I can do everything else from inside the dilaog, such as preview tracks. Just can't import more than one... Anybody seen this? Running LE 7.4cs3 & OS 10.5.2 |
Re: Problem Importing More Than One Audio Track
I am not on Leopard but i have had similar problems going back to 6.x. A work around I found was to isolate the problem track (importing a track at a time until I found one which wouldn't import) then deleting half the regions then trying to import again and repeating the exercise until I had found the suspect .wav file(s). I then used the Audiosuite Gain plug and zero gained the region(s) (ie. made a new audio file copy). I could then import the track. A bit time consuming but when you are doing detailed film work it is worth it! Ultimately your problem is a corrupt audio file in the session.
Good luck! P.S. Or maybe going back to an earlier session file backup will solve the problem!
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7. |
lae777 - the situation you're describing is a different thing. As I say, I can import the files as long as I do them one at a time - there is no one particular culprit. The problem is only if I try to import any number of files greater than one. Anywhere.
It may be a Leopard problem as deluxe suggests. Bit hard for me to check this as both my machines are now on Leopard. But it was never a problem before. |
Sorry Peter,
I wasn't concentrating! I hope that you managed to solve your problem though. Good Luck.
I still have the problem. It happens on both my MacBook Pro and also on my MacPro dual quad, both running Leopard. It's particularly frustrating because I am accustomed to auditioning files from inside the import window so I don't use the 'drag from the finder' option that much.
None of the PTools gurus I know have ideas of what might be causing it, so any help appreciated. |
I'm having the same problem with the import window. One at a time is fine... but it's very frustrating. I'm running PT7.4 on 10.5.6 on a Dual Core Xeon Mac Pro. Anyone know what's with this? I think it started happening after the recent QT update.
Actually seem to have fixed the problem by trashing preferences and restarting as described in the General Troubleshooting Thread. Yay.
QT video, problem importing audio track | CLee | Post - Surround - Video | 1 | 09-06-2012 12:05 PM |
importing audio to track | JAH FYAH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-10-2007 05:18 AM |
Importing audio to track | Peter Groom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-27-2006 08:28 AM |
importing audio to track | nap_complex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2005 05:39 AM |
importing audio to track | russell jack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-26-2004 10:12 AM |
