Old 10-15-2007, 02:38 PM
DrewDrew DrewDrew is offline
Default 8 Seconds To Record?
Every time I try and record, be it a MIDI track, audio track, etc., it stops recording after eight seconds. I've repaired permissions, dumped the Digidesign databases folder, and it won't even let me repair prebinding, claiming everything is okay.
Any suggestions?
MacBook
OS 10.4.9
Intel Core Duo
2 GHz
2 Gb RAM
MBox 2
Pro Tools LE 7.3
Maxtor Firewire Drive (which I'm recording to)
Thanks,
Drew
Old 10-15-2007, 07:44 PM
Slim Shady Slim Shady is offline
Default Re: 8 Seconds To Record?
Are you getting an error message when it stops, or does it just stop on it's own, as if you had hit the spacebar or stop button?
Old 10-15-2007, 08:01 PM
It just stops on it's own with no warning, but every time at 8.x seconds. In fact, if I didn't actually see the transport stop, I wouldn't even know it had happened.
Old 10-15-2007, 08:46 PM
dougied dougied is offline
Does your Maxtor Firewire drive use the Oxford 911, 912, 924 chipset? If not... that also might be a problem. I used to have the same problem until I bought my GLYPH GT050Q external firewire drive, and now everything is fine. I can record forever.
Hope this helps...
-Doug
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 10-16-2007, 06:00 AM
Phil Jeffers Phil Jeffers is offline
It could be the FW drive... I'd try updating to ver 7.3.1cs5 which is recommended for all users. Can you try another FW port? What happens if you try and record to the local HDD? Make sure pre or post roll isn't highlighted... limit undo settings to 5 or 8, try a higher buffer size... 1024 samples... does any of this change it? It's strange that you aren't getting an error message. It makes me think that its a weird preference.
record for a few seconds mrsohl Pro Tools M-Powered (Win) 1 01-14-2010 12:17 PM
Only 5 seconds record time griffiti93 Pro Tools M-Powered (Win) 3 07-30-2008 11:02 AM
Help? Spinning wheel for 10 seconds when trying to record... popps Pro Tools TDM Systems (Mac) 7 01-23-2008 11:27 AM
Pro Tools stalling for 3 seconds on record TC1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2006 10:44 PM
Record delay about 3-5 seconds in protools for osx Janvy Pro Tools TDM Systems (Mac) 3 02-24-2004 07:09 AM
