Old 04-17-2001, 01:44 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 5.1 Session Start—Record Start Interval
There is a condition in Pro Tools 5.1 that can cause "garbage audio". Garbage audio can manifest as noise or audio from random areas on the record drive. This can occur when performing open ended record passes or record passes with large boundaries when there is a large interval between the session start time and record start time. This issue will be fixed in the next free maintenance release of Pro Tools.
The specific condition that triggers this problem is if the number of minutes from session start to record start plus the number of minutes of audio that can be allocated for record is greater than the maximum session length.
At 44.1 kHz:
* Garbage audio is created if (record start - session start) + minutes that can be allocated > 9 hours. "Minutes that can be allocated" is set in preferences.
* Open ended record allocates up to 270 minutes.
* Max session length is 811 minutes.
At 48 kHz:
* Garbage audio is created if (record start - session start) + minutes that can be allocated > 8 hours. "Minutes that can be allocated" is set in preferences.
* Open ended record allocates up to 250 minutes.
* Max session length is 745 minutes.
Example of problem at 44.1 kHz: With open ended recording and a session start time of 1:00:00, (60 minutes) bad data will be recorded if the record start point is past 10:05:00 (605 minutes). i.e. (605 - 60) + 270 is greater than 811.
Workarounds:
1 - Reduce length of time between start of session and record start point to be less than 9 hours at 44.1kHz or 8 hours at 48 kHz.
2 - If the amount of time between the session start and the record in point is greater than 9 hours at 44.1kHz or 8 hours at 48 kHz, open ended record should not be performed and the record length should be bounded by creating a selection not exceeding the following guidelines:
* At 44.1 kHz: (13 hours 31 minutes - [Record Start Time-Session Start Time]) minutes.
* At 48 kHz: (12 hours 25 minutes - [Record Start Time-Session Start Time]) minutes.
Digidesign Technical Support
Administrator
Old 04-17-2001, 03:19 PM
uno1234 uno1234 is offline
Default Re: Pro Tools 5.1 Session Start—Record Start Interval
So it seems to me that you only have to worry about this problem IF you have a lot of "blank space" between the session start and audio data, and/or if you don't "limit record time" in the preferences...?
This may be simply repeating what was stated above, but I'm trying to understand it. This seems to be a problem for people doing concert recording (or something similar), but not a problem for people recording 4-5 minute songs...?
Old 04-17-2001, 03:44 PM
Jules Jules is offline
So, someting like "Jail House Rock" would be Ok then?
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 04-17-2001, 05:08 PM
Avid's Avatar
Administrator
It is a bit technical, but the first workaround is the clue:
"1 - Reduce length of time between start of session and record start point to be less than 9 hours at 44.1kHz or 8 hours at 48 kHz."
If the length of time between your session start time and record start point is less than 8 hours, the problem described is non-existent.
Bruce Paine
WebAdmin
Digidesign Customer Service
Administrator
Old 04-18-2001, 08:27 AM
Mark Wheaton Mark Wheaton is offline
I don't know if this relates but I got garbage in the form of white noise/slowed down indeterminate audio at the end of a 3 minute bounce that was within 6 minutes of session start. I was bouncing with Master X. By changing the end time of the region and/or creating a fade out, it went away.
Can't even start a new session on Pro Tools SE 8.0 soundsofviolence Pro Tools SE and Essential (Win) 0 01-19-2013 03:58 PM
Lion Pro Tools SE won't start on one account, but start on another AndrewGalas Pro Tools SE and Essential (Mac) 2 12-15-2011 11:06 AM
Can I start Playback at Session Start Time? LSW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-19-2006 03:04 PM
audio record volume errors cant start session ninjastanki1100 Pro Tools TDM Systems (Mac) 1 07-22-2005 01:52 PM
Delayed record start in Pro Tools 5.1 SteveGarman Pro Tools TDM Systems (Mac) 11 06-21-2001 06:08 AM
