Old 08-12-2006, 09:19 PM
teleguy2 teleguy2 is offline
Default Roland 1680 to Protools via Projectmix i/o
Anyone know how to do this? Or know where it's posted?
I've been using a 1680 for several years and I've finally made the leap to PT with the help of a friend.
Can anyone give me some basic steps to easily (or as easily as is humanly possible) transfer my tracks over into ProTools with minimum loss of quality...and I am a complete newbie with ProTools, so try not to speak in abbreviations and codes if at all possible.
My drummer set up the system for me (he runs a studio and is good at it). All I know how to do is get sounds into ProTools and move faders up and down. I'm learning, but I also have two kids and work full time (NOT in a studio), so I'm on an extreme learning curve.
So, any help you can give a brother would be much appreciated.
Peace,
Steve
Old 08-12-2006, 09:54 PM
beggehorn beggehorn is offline
Default Re: Roland 1680 to Protools via Projectmix i/o
Sounds like a great question to ask your friend...
Nice to see you round these parts teleguy2
Windows 10 Pro x64
Avid HDX running PT Ultimate 2020.x
ASUS WS x299 SAGE 10g
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
Old 08-14-2006, 10:26 PM
anyone?
anyone?
Bueller?
Old 08-15-2006, 12:11 PM
TBF Entertainment TBF Entertainment is offline
I came from a 1680 also. There is no real easy way of doing it. Only 2 ways.
1) Use the main outs and the Aux outs for a total of 4 outputs. You will just have to fly them in 4 tracks at a time. Then at the end Make sure to line them up. Actually, what i haven't tried was to sync to ProTools. That may work also so you don't have to line them up manually. Also, you are now analog, so you will have some noise. But i haven't really heard a difference.
2) Use the Digital Outs from the 1680 into ProjectMix. You stay in the digital domain, but you only have 2 tracks at a time. Takes a longer time.
Let me know if I can help you with anything else.
tbf
Old 08-15-2006, 11:52 PM
TBF,
Thanks! Just today on the VSPlanet forum I also received this advice. Does it make sense/sound legit to you? I'll repost it here for a comparison/contrast of information.
You can send tracks out from a 1680 via:
* the digital outputs, two at a time
* the RCA outputs, eight at a time
Before you send any tracks out of a VS into a computer, you'll need to "mark" them, such that you can line them up in the computer program you'll be working with. Take a stick click or something - one short noise - and copy it to the same time coordinates at the beginning of each track. (You can mark one track, then copy a clip from that track to the same location on every track using the Copy menu).
To send tracks out the digital output:
1. On the track menu of the VS, pan the first track hard left and the second track hard right.
2. Turn down the output volume on all your other tracks.
3. Make sure you are routing the output to the digital outs.
4. Hook the VS digital outputs to the digital input of your i/o device, making sure that the sample rate is the same (for example, if you recorded the tracks on the VS at 44.1, the computer needs to be at 44.1 as well).
5. Arm the tracks in the computer.
6. Press "play" on the VS.
Voila! Now repeat this process for all your 1680 tracks.
The process is the same for the analog outputs, except that you use the Direct Out switch on the Master Block to send the contents of tracks 1-8 and 9-16 out the RCA outputs in the back. You can skip the part about panning the tracks - when you use the direct out method, panning doesn't matter.
Hope that helps.
And here's a link to that post and it's ongoingness.
That OTHER message board.
Old 08-17-2006, 07:24 AM
It sounds good, except for the 8 outs. The most I could find to do was 4 outs. How did he get 8 outs? There is no way, to my knowledge to use all RCA outs, each with only 1 track going out of it.
Otherwise, yes, it sounds right.
TBF
Old 08-20-2006, 05:26 PM
ramkid ramkid is offline
The best way is if you can find someone who has a VS2480, a Delta Rbus card and M Powered on a Windows computer and have them transfer the files via Rbus directly into M Powered. I have this setup, but I run M Powered on a Mac and for some strange reason, Mac M Powered will not see the Rbus card. But if all else fails and you don't have to many items you want to transfer, I could help you out. PM me over at VSPlanet, I am mackid over there.
ramkid
getting tracks from a roland 1680 into protools? [email protected] Pro Tools TDM Systems (Mac) 2 02-27-2005 10:11 PM
Multitrack I/O from a Roland VS-1680 Zumwalt General Discussion 2 08-27-2002 05:40 PM
Roland VS 1680 musicstudio58 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-19-2002 01:18 PM
Roland VS-1680 help flugleboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-13-2001 10:00 AM
Roland VS-1680 to PT How? SCSI? Corey Shay Tips & Tricks 15 01-13-2001 04:07 AM
