Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #61
Old 04-09-2024, 04:54 AM
RobertDorn RobertDorn is offline
Default Re: Can TB3 be the only connection to the Mac?
Interesting topic to read:) actually always wondered what wizardry made it happen that when overdubbing with an Apollo (monitoring through console, same principle as when monitoring the incoming signal directly through the MTRX by connecting the dots in DADman) made it happen that even when dubbing in on a pro tools session with some sample heavy mastering processing on the masterbus already, everything ends up perfectly in time. If I understand it all right the DAW just reports this back to the core audio driver. Cool.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
  #62
Old 04-09-2024, 12:27 PM
The DAW does not report latency to the driver, it's the other way around. At some point in setting stuff up the DAW asks the driver for its latency data and then uses that as described in this thread. All the timing/latency adjustment happens purely in the DAW.
You will have to look through what is happening in any dubbing situation. e.g. if (UAD console) hardware or software monitoring is being used, if plugins are enabled or disabled on monitoring paths, what the actual latencies are, etc.
  #63
Old 04-09-2024, 01:56 PM
mmm perhaps then it's a feature in Pro Tools with LLM enabled, like, if Pro Tools knows the session delay is 8000 samples, and you'll use hardware monitoring, it 'knows' to print the audio clip 8000 samples to the left because it was performed to a mix heard 8000 samples later. Or something:) then I don't yet factor in the RTL as discussed above in this thread. At least in practice, it turns out to work flawlessly for me.
Connection? L-Dogg Eleven Rack 3 06-15-2011 07:52 PM
connection ok? dogselur Pro Tools M-Powered (Win) 5 02-01-2006 07:40 PM
FW connection Kim (Mbox) Pro Tools M-Powered (Win) 0 06-22-2005 09:33 AM
Connection Tintin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-10-2005 07:17 AM
DAT Connection Help! popps 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-15-2001 02:12 PM
