Old 08-01-2019, 09:29 PM
EddieJones's Avatar
Default New Software Release EuControl Version 19.7.0
Avid is pleased to announce the release of EuControl/Workstation software version 19.7 for the S3, Dock, Pro Tools|Control, and Artist Series. Log in to your Avid Account (for S3, Dock, and Pro Tools | Control) or My Artist portal to download the new software.
Whats new in EuControl 19.7.0
Old 08-02-2019, 01:35 AM
mattrixx mattrixx is offline
Default Re: New Software Release EuControl Version 19.7.0
Thanks Eddie,
Initial "couple of hours in" report... seems to be more stable (especially with the Control app not dropping off every now and then). Feels great
...and great option additions IMO
Unfortunately, I still don't see any available Eucon Midi ports for MCU or HUI support (tried all network port avails in System Prefs too).
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 08-02-2019, 10:52 PM
Angel Xerran's Avatar
Angel Xerran Angel Xerran is offline
Hi Eddie,
I updated to the new EuControl 19.7.0 a few issues where fixed for my S3 but now there is a bigger issue with the flip function. When I flip my faders to Aux or Pan when I move the fader it changes the Volume of the specified track, so if I want to automate a send it doesn't work, it's overwriting the volume instead. It cannot be my setup cause I've been mixing all day, all week and everything was fine before the update.
MacOS High Sierra 10.13.6
Pro Tools 2019.6.0
Avid S3 + Pro Tools Dock
Last edited by Angel Xerran; 08-02-2019 at 11:15 PM. Reason: added my system specs
Old 08-02-2019, 11:02 PM
I've noticed a few have mentioned this, so I thought I'd check it. And although not particularly helpful, this is not happening in my setup.
Matt McKenzie-Smith
mattrixx.net
Old 08-03-2019, 12:47 PM
remainanon remainanon is offline
As of this moment, the current version of Pro Tools |Control (ipad) and the new updated Eucontrol, with the firmware pushed to an S3, are not compatible.
Adding the PT | Control in the Eucon app throws the message attached here
(( duc would not host the image, but it is a dialog that says "Pro Tools | Control cannot be added because it is not compatible with the installed version of EuControl…"
Both were downloaded & installed moments ago
Cheers
JW
Old 08-03-2019, 01:05 PM
BScout BScout is offline
They are here and elsewhere.
Can you post full version numbers of what is installed? Specifically the iPad (gear > about).
Should be 19.7.0.101 for Eucontrol and 19.7.0.95 for the iPad.
(and if you haven't tried, close the iPad app and make sure it disappears from available Eucon surfaces, and then reopen it and see if it pops back up)
Old 08-03-2019, 01:31 PM
Thanks
It looks like the iOS version might be the hangup. Trying that
Cheers
JW
Old 08-03-2019, 03:07 PM
… It was iOS. Had to cold restart everything after the update, but after all that…
… JOY
Thanks folks
JW
Old 08-04-2019, 10:59 AM
J-S-Q J-S-Q is offline
A very big thanks for this fix:
• S3 faders could cause unexpected changes to values in Cubase (GWSW-11553)
Old 08-06-2019, 03:15 PM
Is there any update coming soon?
I'm not able to use my iPad since the last update, I downgraded EuControl on my Mac because of the automation issue with the S3 and the iPad app is not compatible anymore. I'm scared of updating because everytime that something gets fixed something else get screwed.
New Software Release EuControl Version 19.5.1 EddieJones Avid S1, S3, Dock and Control App 1 05-09-2019 03:50 PM
New Software Release EuControl Version 18.3 EddieJones Artist Series 26 04-05-2019 01:10 PM
New Software Release EuControl Version 18.3 EddieJones Avid S1, S3, Dock and Control App 12 11-10-2018 02:43 PM
New Software Release EuControl Version 3.7.0 EddieJones Artist Series 0 10-19-2017 12:09 PM
New Software Release EuControl Version 3.7.0 EddieJones Avid S1, S3, Dock and Control App 0 10-19-2017 12:08 PM
