Old 07-23-2019, 11:53 AM
julien-k julien-k is offline
Default I/O Problem
Running PT 2018.10.0
iMac High Sierra 3.5 GHz Intel Core i7 32GB RAM
Made some minor name changes to my outputs in the I/O screen (before opening a session) and exported them to use. When I open old sessions and import the new I/O settings it just gives me two outputs? Even though all the settings are labelled and setup correct on my I/O page?
Found a work around - within the old sessions I delete the output paths in the I/O and redo them the exact same way then they show up! What's up with this? Anyone have any incite? Thank you!
Old 07-23-2019, 02:41 PM
Default Re: I/O Problem
I think you have figured out the only option is to revisit IO settings every time you open an older session. Same thing can happen when opening a session from another system(and remember to update any/all session templates and track presets)
Old 08-23-2019, 05:10 PM
Thanks I guess it just doesn't work as easy as I had hoped. You'd think by now this would be a lot easier???!!!
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? Priz Windows 1 09-25-2011 12:51 PM
ELS Vocoder plugin problem and fresh Windows 7 install problem Thorpey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-09-2011 05:03 AM
Need opinions: Do I have Core card problem or computer problem? johnnyv Pro Tools TDM Systems (Mac) 2 08-11-2010 06:36 PM
digi 002/7.4 installation problem/not recordable volume problem fifthflaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2008 01:28 PM
Audio Regions Display Problem & Grabber Problem markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-25-2002 04:08 AM
