Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-30-2017, 04:06 PM
junkgear's Avatar
junkgear junkgear is offline
Thumbs up Focusrite Clarett Windows Running Well :-)
I just upgraded my Windows PC and wanted to give Thunderbolt a try, so I picked up a Focusrite Clarett 4Pre to replace my ageing FireWire interface.
My PC has a TB3 port, so I'm using an Apple TB3 to TB2 adapter. Installation was simple and Focusrite Control works well. I run my system at 48Khz with a 128 buffer and the latency is low enough to track with plugins. Everything is working well with PT with no dropouts or clicks/pops.
FireWire was good, but TB is definitely better.
Anyone else running Clarrett or other TB interfaces?
Will
System Details
Old 04-30-2017, 07:19 PM
nige108's Avatar
nige108 nige108 is offline
Default Re: Focusrite Clarett Windows Running Well :-)
Yep, same set up. W10, Clarett 4pre. TB Adapter. All good here too.
Old 10-27-2017, 01:21 PM
vibrochump vibrochump is offline
Hey guys. I just got my new PC build up and running and I am having some issues getting the focusrite clarett 4 pre to work with pro tools 12.5.2 The thunderbolt card was activated in the bios and is recognized by windows 10 pro and the clarett 4pre. The message I get after launching pro tools is "pro tools could not initialize the current playback device, please make sure the device has been configured correctly". I am using the only driver available on the focusrite site, 2.1.4 and I have uninstalled it and reinstalled it with no luck. Did you guys have to do any special configuring to get the 4 pre to work with pro tools? I am using the apple thunderbolt 3 to thunderbolt 2 adapter with my asus x99 deluxe ii and the asus ex3 thunderbolt card that came with the motherboard.
Old 10-27-2017, 03:10 PM
Southsidemusic's Avatar
Welcome to the Community
Have you tried launching PT with the N key held down and choose the Clarett when the popup window appears, That usually forces PT to take hold of the Interface.
Let us know what happens.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-27-2017, 03:31 PM
My guess is that Windows or something else is accessing the interface. Go to Sounds in the Control Panel and be sure the Clarett is NOT selected as the default playback device.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 10-28-2017, 07:23 AM
Hey guys thanks for the help, those suggestions did the trick. My new system is finally up and running. So far so good using thunderbolt with windows 10 pro and the clarett 4pre. And pro tools 12.8.2 r2 seems to be working good as well. Obviously a lot more testing to come. I was on 12.5.2 for a long time, so hopefully they have most of the bugs worked out:) Thanks again.
Old 03-07-2018, 05:09 PM
Dalx Dubai Dalx Dubai is offline
I just got my clarett 4pre but for some reason my audio is clicking and popping. From watching YouTube videos to working in FL Studio, clicking and popping noise. Any suggestions?
Old 03-19-2018, 07:23 AM
junkgear's Avatar
Not sure what sample rate you are running at, but as a first step, I would increase the buffer. I have to run 256 on my system; anything lower and I get clicking and popping. If that doesn't work, try a lower sample rate as well. You might have to play around with these two settings until you figure out what your system can handle.
Will
System Details
Focusrite Clarett 2Pre/Clarett Octopre w/PT11 shultzee13 Pro Tools 11 0 03-24-2017 08:08 PM
PTMP 8 not seeing focus rite 18i8 thecaptainandme macOS 3 11-19-2013 12:12 PM
running PT 8.0 in windows XP virtual machine on windows 7 Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 03-17-2010 08:45 PM
RiTE ON! kidfrenzy General Discussion 0 05-30-2001 10:04 PM
EQ Write to End Focus Rite David Carstairs General Discussion 0 05-08-2001 03:28 AM
