Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-15-2015, 02:55 PM
JohnPlaysWithFire JohnPlaysWithFire is offline
Default M-audio ProjectMix I/O Problem.
I bought a Projectmix second hand and it didnt have a power supply. So I bought a replacement, and now its a whole different issue...
The LCD screen just shows boxes all the way across, never any actual text... Occasionally the MIDI window on the unit will either say "8" or "88" and both MIDI LEDs will be on. Once i've had it light all the buttons on channel 8, and a few other buttons, but i dont remember which. Any idea what could be causing these issues? Is the unit dead or is there some kind of hope for it? I've attached a few pictures to make what im talking about a little easier to understand.
Thanks.
Old 06-15-2015, 02:58 PM
Southsidemusic's Avatar
Default Re: M-audio ProjectMix I/O Problem.
Hi
What is it connected to? Mac/Win and what DAW? Version? I don't know if it would display anything other than a blank row if it isn't connected to something, Not standalone
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-15-2015, 03:00 PM
Originally Posted by Southsidemusic View Post
Hi
What is it connected to? Mac/Win and what DAW? Version? Etc etc
Mac Yosemite. Pro Tools 12(but i have earlier versions i could use, but i havent even got the unit to get that far) the M-audio firewire software pops up not connected, but like i said the unit doesnt really pop anything up on the LED screen, which makes things twice as difficult.
Old 06-15-2015, 03:06 PM
mesaone mesaone is offline
Turn the unit on while holding down the ZOOM button. It will go into test mode. Does the display function then?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 06-15-2015, 03:17 PM
bradch00 bradch00 is offline
What version of the driver are you using? Keep in mind that the last driver doesn't support Yosemite, so it's functionality is quite limited (i.e. you can't change screens in the driver) I use mine only as a control surface.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 06-15-2015, 03:22 PM
Hmmm. It still does the same thing. all the preamp "signal" LEDs flash green(does this even without trying to test) This isnt looking good for the unit i suppose.
Old 06-15-2015, 03:24 PM
If you entered test mode correctly, there should be a few different messages that show up on the screen, followed by simulated meter activity (along with fader movement and button illumination). You got none of that?
Old 06-15-2015, 03:30 PM
Where did you get the replacement power supply?
Nothing. if the unit is on, fader 1 will jump back down if i push it up. But holding the zoom button while powering on doesnt do anything. i waited about 45 seconds after the signal lights flash, but still nothing. The screen still shows the boxes like it has been doing. any idea if a loose connection inside could cause any of this, or is the CPU of the unit probably shot? Im starting to feel like there isnt much hope for the unit, since it wont even go into the test mode.
Old 06-15-2015, 03:33 PM
Ebay. I know, i know, mistake number one. but even on amazon it was the same option. I checked all the rating on the power supply before plugging into the unit, and they all match up.
M Audio ProjectMix I/O peter5992 Post - Surround - Video 2 09-16-2012 08:22 PM
M-Powered 7 & Projectmix I/O problem Rowenna Pro Tools M-Powered (Win) 1 05-24-2008 12:40 PM
003 vs. M-audio projectmix I/O sos4e 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-09-2007 03:16 PM
projectmix problem jeanhewi Pro Tools M-Powered (Mac) 6 04-11-2007 03:47 PM
projectmix problem jeanhewi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-27-2007 04:08 AM
