  #231
Old 09-20-2019, 01:41 AM
Oliver M Oliver M is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Originally Posted by echoesoflife View Post
Here is the part of the code where Shift modifier doesn't work:
Originally Posted by henningaround View Post
Maybe you can avoid this by using a memory locations with a selection which always has the number 999. So you can locate to it by hitting ,999, on the keypad (inside your script).
echoesoflife,
what Henning wrote is the easiest solution.
If you want to pick specific Memory Locations (i.e. Start is marker #1 and End is marker #999) you can do it like that:
Code:
property shortDelay : 0.1
property medDelay : 0.3
tell application "System Events"
	tell process "Pro Tools"
		set frontmost to true
		-- Select Marker #1 - Top
		key code 65 -- , key
		keystroke "1"
		key code 65
		delay medDelay
		-- Extend selection to Marker #999 - End
		try
			key down {shift}
			delay shortDelay
			key code 65
			keystroke "999"
			key code 65
			delay shortDelay
			key up {shift}
		end try
	end tell
end tell
The Memory Locations window doesn't even have to be open for this to work.
Keep in mind that you should wrap the key down and up commands in a try block as those keys can get stuck!
  #232
Old 09-20-2019, 02:12 AM
echoesoflife echoesoflife is offline
Thank you kindly! I'll give it a try and will report back then.
  #233
Old 09-21-2019, 12:15 AM
Hi all,
The shift modifier still doesn't work. Everything else is spot on, the script correctly selects the markers and proceeds to click all the buttons. However the Shift is not held down, hence the selection is not made.
I am wondering if I have missed a particular setting for System Events to respond to that command? Weirdly enough, in Settings - Security & Privacy - Privacy I have System Events, Automator and even the particular script enabled.
Any pointers would be greatly appreciated!
  #234
Old 09-21-2019, 12:54 AM
henningaround henningaround is offline
Try using just one memory location with a selection so you don't need a shift click.
  #235
Old 09-21-2019, 01:21 AM
Hi all,
Weird. Post your complete script and I will have a look. The shift click should work fine. I use such a script (to make a selection from top to end of session) daily and it never fails.
  #236
Old 09-21-2019, 08:13 PM
Thank you Oliver.
Here's the current version of my complicated Memory Location selection.
I see the script clicking on markers correctly, but the Shift is not engaged during the process.
Interestingly enough, today I am experiencing Shift being engaged after the script has finished. Even though it is wrapped around try code.
When I am trying the version of the selection that you have suggested, the script would not click on any of the markers.
It is worth noting that I am using a Hackintosh system, and I am on High Sierra.
Thanks again for your time!
Code:
on doWithTimeout(uiScript, timeoutSeconds)
	set endDate to (current date) + timeoutSeconds
	repeat
		try
			run script "tell application \"System Events\"
" & uiScript & "
end tell"
			exit repeat
		on error errorMessage
			if ((current date) > endDate) then
				error "Can not " & uiScript
			end if
		end try
	end repeat
end doWithTimeout
activate application "Pro Tools"
set timeoutSeconds to 0.2
-- Click the “Window” menu.
delay 0.4
set uiScript to "click menu bar item \"Window\" of menu bar 1 of application process \"Pro Tools\""
my doWithTimeout(uiScript, timeoutSeconds)
-- Memory Locations
delay 0.5
set uiScript to "click menu item \"Memory Locations\" of menu \"Window\" of menu bar item \"Window\" of menu bar 1 of application process \"Pro Tools\""
end run
--selection of markers from Start to End script
		set asWindow to (1st window whose name contains "Memory Locations")
		try
			key down {shift}
			tell asWindow
				-- click "Start"
				repeat with aRow in row of table "Memory Locations"
					if name of static text of UI element 2 of aRow starts with "Start" then click static text "Start" of UI element 2 of aRow
				end repeat
				-- click "End"
				delay shortDelay
					if name of static text of UI element 2 of aRow starts with "End" then click static text "End" of UI element 2 of aRow
				end repeat
			end tell
			delay shortDelay
			key up {shift}
		on error e number n
			tell application "Pro Tools" to display alert "An Error Occurred" message e & " (" & n & ")" buttons {"Cancel"} default button 1
		end try
	end tell
end tell
-- Press ⌥⌘B
delay 0.5
set uiScript to "keystroke \"∫\" using {option down, command down}"
-- Click the “Offline” checkbox.
set uiScript to "click checkbox \"Offline\" of window \"Bounce\" of application process \"Pro Tools\""
-- Click the “Bounce” button.
set uiScript to "click UI Element \"Bounce\" of window \"Bounce\" of application process \"Pro Tools\""
-- Click the “OK” button.
set uiScript to "click UI Element \"OK\" of window \"MP3\" of application process \"Pro Tools\""
end run
  #237
Old 09-23-2019, 01:48 AM
Thank you Oliver.
Code:
	repeat
		try
" & uiScript & "
end tell"
			exit repeat
			end if
		end try
	end repeat
end doWithTimeout
delay 0.4
-- Memory Locations
delay 0.5
end run
		try
			key down {shift}
			tell asWindow
				-- click "Start"
				end repeat
				-- click "End"
				delay shortDelay
				end repeat
			end tell
			delay shortDelay
			key up {shift}
		on error e number n
		end try
	end tell
end tell
-- Press ⌥⌘B
delay 0.5
end run
You are still using your old code to make the selection, which doesn't work. Click your start and end positions by number, try the example I posted in post #229.
  #238
Old 09-23-2019, 04:41 AM
Thanks Oliver.
Yes, indeed.
I did try your suggestion, and the markers are not getting selected.
Here's the code that I tried:
Code:
	repeat
		try
" & uiScript & "
end tell"
			exit repeat
			end if
		end try
	end repeat
end doWithTimeout
		keystroke "1"
		key code 65
		delay medDelay
		try
			key down {shift}
			delay shortDelay
			key code 65
			keystroke "999"
			key code 65
			delay shortDelay
			key up {shift}
		end try
	end tell
end tell
-- Press ⌥⌘B
delay 0.5
end run
Pro Tools 2019, Hackintosh High Sierra
  #239
Old 09-23-2019, 10:08 AM
echoesoflife,
here is a combination of cliclick and the key down and up commands that does what you want (it clicks the actual markers by name).
I also added some code to check whether the Memory Locations window is open and if not opens it.
This works flawlessly here.
Code:
property cliclickCLIPath : missing value
set cliclickCLIPath to "usr/local/bin/cliclick"
		-- Open Memory Locations window if it is not open already
		if not (exists window "Memory Locations") then
			click menu item "Memory Locations" of menu "Window" of menu bar item "Window" of menu bar 1
			repeat until exists window "Memory Locations"
				delay shortDelay
			end repeat
		end if
		-- Set variable for Memory Locations window
		set mlWindow to (1st window whose name contains "Memory Locations")
		delay shortDelay
		tell mlWindow
			try
				-- Click "Start" marker
						tell static text "Start" of UI element 2 of aRow
							set {xPosition, yPosition} to position
							set {xSize, ySize} to size
							my cliClick("c:" & xPosition + (xSize div 2) & "," & yPosition + (ySize div 2))
						end tell
					end if
				end repeat
				-- Click "End" marker and extend selection
						tell static text "End" of UI element 2 of aRow
							key down {shift}
							key up {shift}
						end tell
					end if
				end repeat
			on error e number n
			end try
		end tell
	end tell
end tell
on cliClick(process)
	do shell script quoted form of cliclickCLIPath & " -r " & process
end cliClick
I have no idea what your extra uiScript does but if the above code still fails on your machine then I suggest to have a look at that particular script.
Last edited by Oliver M; 09-24-2019 at 07:01 AM. Reason: Corrected/added a few comments.
  #240
Old 09-24-2019, 02:48 AM
Works like a charm, thanks kindly!
I am going to finish the script into a little app where you could select Online/Offline Bounce, Bounce location and select a few projects to bounce.
Once I am done, I will share the source code and the app here.
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
