Old 04-22-2012, 04:49 AM
juliancallan juliancallan is offline
Exclamation M Powered 7.4 and Fast Track issue
Hey all.
I was recently given a copy of Pro Tools M-Powered 7.4, an iLok and a M-Audio Fast Track USB device from my Sound lecturer in college.
After installing everything properly from a fresh Win7 installation, everything was fine until I load up Pro Tools and get the error "Unable to locate M-Audio Hardware. Please check your hardware is turned on and restart Pro Tools"
I tried to do it on a fresh Windows XP installation, thinking this would help but still the same issue.
The thing is, the Fast Track is recognized in Windows and works fine with Reaper or as a playback device.
I've read all the posts here about people who had the same problem but I can't for the life of me find a solution, has anyone any ideas?
Could it just be that the Fast Track won't work with M-Powered software?
Thanks so much.
Attempted fixes: Everything from formatting 7 to installing XP on a new partition and still no joy. All drivers reinstalled and everything. Changed USB slots, turned off Power management on USB.
Recent changes: Installed on a clean install of 7 and XP and no joy.
Operating system: Tried on both Windows 7 32 Bit and XP SP3
System specs: M-Audio Fast Track, Pro Tools M-Powered 7.4, iLok
Old 04-23-2012, 05:42 AM
mikeysax mikeysax is offline
Default
Maybe you should check if new audio drivers are available for your interface. Or just reinstall the drivers without the interface plugged in the usb port. Also, some usb devices shut off as a standard power saving method for many Pc computers. In the device manager you should make sure all the usb ports never turn off to save power consumption. I think your maudio fast track is compatible with pro tools le. So, probably an audio driver problem. Make sure the maudio interface is set to playback option in the sounds device properties.
Good luck.
Sent from Mikey's Super INSPIRE 4G....
mac osx, m powered fast track, pro tools m powered singdance6 Pro Tools M-Powered (Mac) 2 12-22-2010 09:24 AM
Fast Track M-Powered Essential rhendee Pro Tools M-Powered (Win) 2 11-11-2009 02:00 PM
M-Powered & Fast Track USB DJ Blue Pro Tools M-Powered (Win) 0 02-13-2009 07:06 PM
M-Powered issue with M-Audio Fast Track USB Jesse1 Pro Tools M-Powered (Win) 8 11-27-2006 12:54 AM
M Powered&Fast track Pro not open It sucker002 Pro Tools M-Powered (Win) 2 10-11-2006 12:55 PM
