Digital split
Hi!
Is there some easy way to do digital split when foh is using Profile system and monitor world use Mix Rack system? |
Re: Digital split
Yes Via the Venue MAdi Card
Your Profile surface at FOH is a Mix Rack of FOH/Stage rack system ?? |
Re: Digital split
In this case foh console is Profile system (stage rack, digi snake and foh rack) and monitor mixer is Profile with Mix Rack System. Problem with MADI is that it is in FOH rack, not in Stage Rack. Any ideas?
Re: Digital split
Using a MADI option is d simplest way to lay an optical cable from Mixrack to FOH I think...
And U Can Use some Digital Output cards(DSO) @ stage rack + some Digital Input cards(DSI) @ Mixrack.(Basically, wether its helpful or not, mixrack has 10 line inputs) DSO sends signal through AES/EBU and optical simultaneously. or DSI(stage rack) + RME ADI648 + MADI option, u can use 48ch other mixrack input + 16 MADI input BUT Not Good Ideas |
Re: Digital split
I've used the MADI digital split a good amount. It is very reliable and works flawlessly. My only "not favorite" thing about it is the slave console does not automatically gain comp when a change is made on the primary console. It is what it is...I just have to relay to my monitor engineer when I am making a gain adjustment so he can prevent surprises. I would not doubt it will be too long before AVID releases a gain comp feature. Afterall...they did the programming of the GAIN transfer feature for virtual soundcheck...it couldn't be much harder than that
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Re: Digital split
Digital input split | gcpsoundlight | VENUE Live Sound Systems | 4 | 01-10-2012 11:09 PM |
D-Control 32 split or no split? | Don Geppert | ICON & C|24 | 8 | 01-30-2007 10:15 AM |
MIDI Split | sixways | MIDI | 6 | 05-07-2006 09:48 AM |
split a session? | widdly wow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-01-2003 06:51 PM |
Mix Split Question with 192 i/o | Digi-Slime-NYC | Pro Tools TDM Systems (Mac) | 9 | 06-05-2002 12:35 AM |
