Old 08-25-2019, 03:13 AM
danyg danyg is offline
Default CPU question mono vs stereo
I made some tests without clear/satisfying results and I was asking myself:
if
- a MONO channel with with mono plugins has less CPU usage than a stereo channel (we get a lot of stereo bounces these days from mono tracks) ?
- there is a difference between PT plugins behaviour and 3rd party plugins - I tried 40 Waves Plugins in mono and stereo and got no real difference in CPU
- is it worth to split the stereo tracks that don't need to be mono (or just a loss of time)
What is your experience? Thanks
PS: OSX PT 2019 - I'm not talking about multi mono.
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 08-27-2019, 03:08 PM
Default Re: CPU question mono vs stereo
no-one with more information?
Old 08-27-2019, 03:14 PM
off the wall's Avatar
if
I always split real mono tracks if delivered as stereo. It just makes panning, bussing etc easier. It also takes 1/2 the voices. I gotta believe that most plugins use less CPU in mono but have no real proof that is so.
offthewallproductions
Old 08-27-2019, 03:51 PM
BScout BScout is offline
https://www.soundizers.com/
panning stereo tracks that are actually mono is an annoyance which is the first reason to get rid of them.
Old 08-27-2019, 07:46 PM
cwsand's Avatar
cwsand cwsand is offline
Yes, and they just make the session larger.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-28-2019, 12:38 AM
- BScout,
I have Soundizer but I find the algorythm a bit too "strict". If there is a tiny bit of noise on one side of a stereo kick or snare it doesn't convert it to mono. Wish it was a bit more loose (if that makes sense).
- off the wall,
So Vanilla can play 256 mono tracks ?
The CPU window is so sluggish. You can almost read nothing concrete
Old 08-28-2019, 06:30 AM
- off the wall,
No, Vanilla can play 128 VOICES at 48k. That would be 128 mono tracks or 64 stereo tracks.
Old 08-28-2019, 09:05 AM
JFreak JFreak is online now
That is incorrect -- Vanilla can play 128 audio tracks, mono or stereo, and don't care about voices at all. AFAIK that is, correct me if things have changed lately with the new voice packs that I don't have and think are Ultimate-only anyway.
Voice is a DSP concept that means i/o point of mixer.
EDIT: this thought haunts me now, please someone test if creating 128 stereo tracks is possible with vanilla (cannot test myself with this license bundle)
Old 08-28-2019, 09:10 AM
I was just going by what AVID had to say about it here:
https://www.avid.com/pro-tools/comparison
What is a voice?
"A voice is a single audio stream that roughly equates to one mono audio track. A mono audio track will use one available voice. A stereo track will use two available voices. The voice limit is Pro Tools' capacity to play back a multitude of simultaneous voices. The higher the voice limit, the more tracks you can play back in Pro Tools to work on bigger, more demanding sessions."
Old 08-28-2019, 09:12 AM
Yes, that is a voice. But standard software is not about voices, that ad material is talking about tracks (mono or stereo bcs greater-than-stereo are not available). Voices are only used/calculated in HD/Ultimate. Maybe if all users could do their math it would have been simpler for Avid to allow 256 voices for standard software but as most are only counting tracks limiting to 128 seems sensible.
Stereo to mono question stixman Tips & Tricks 1 09-01-2016 01:45 PM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
mono/stereo question studiokeyz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-13-2008 01:25 PM
Stereo / Mono question Daubian Tips & Tricks 2 03-16-2007 04:26 PM
Stereo or mono, that's the question. rgr VENUE Live Sound Systems 5 03-06-2006 02:32 PM
