#21
Re: Reason Upgrade to 10 for $99
Actually a third - you don't have to deal with the vagaries of Rewire. |
#22
How does accessing additional cores effect over all performance? Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#23
As far as accessing all cores in VEPro I can run more heavy cpu usage plugins like Kontakt 5 with heavy scripting libraries/sounds than in PT. I don't see one or a couple of cores overloading like I would in PT. Granted it's not an easy program to wrap one's head around; when I started with it I actually sat down and mapped out on paper (imagine that) the routings from PT to VEPro and back just to keep things straight. This is the one thing Vienna's documentation falls flat on and for me I've found going old-school like I did keeps my head screwed on straight. |
#24
I haven't yet taken the plunge into Kontakt, but as I do more in the video/game/film score area, I have a feeling I'll need to, if only to be able to use some of the great sample libraries out there for it, like 8dio among others. Thanks again for filling me in.
#25
Upgrade is a great deal, but since I haven't fired up reason in a while I forgot about the Codemeter auth system if you're not online. Not a deal breaker, but not welcome
How are you doing this without the 3rd party plug Rewire-VST? Reason doesn't appear as an available VST plug in VEP. Otherwise you're just using rewire wrapped in a VST adapter.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#26
I read that online is only for download and authorization You don’t have to remain online to run R10 do you?
#27
If there's a way to download your authorization codes and store on your OS drive, I'm not aware of that. Maybe someone else would know. I have the key on my studio rig, so never give it a thought. But I have second installation on my laptop, which I use mainly to create sounds I'm using when I play at my church, and for that I have to have an internet connection to boot up Reason since I don't carry my Ignition Key around with me.
#28
You can authorize the computer, but you have to install the Codemeter runtime app - it does not require a key also. If you don't want to do that, you can just sign into your account each time you run the program.
#29
There isn’t. You either use the dongle or you log in and auth while your computer is online. Never tried logging in and disconnecting the network connection so can’t comment on that. It might work. I’ll try to remember to test that when in front of my rig. Sent from my iPhone using Tapatalk |
#30
You can authorize the computer with out a key and you can run Reason 10 offline. Install Codemeter runtime --> log into your account at Propellerheads --> Under your products click the Authorize button and follow instructions to store licenses to your computer.
Any reason to upgrade to 12.5.2? | PatriotsBiker | Pro Tools 12 | 4 | 07-17-2016 03:43 PM |
help with 7.3 upgrade and reason | crowdpusha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-14-2006 07:34 PM |
Reason Upgrade? | DazedAndConfused | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 03-01-2006 04:22 AM |
Reason 3.0 upgrade | bassbuddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-03-2004 06:50 AM |
Upgrade PT Reason Adapted to FULL Reason ...Price? | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2003 07:04 AM |
