Old 10-15-2014, 04:40 PM
Nathan W. Nathan W. is offline
Default Insertion Follows Playback 29.97 df bug
There's an old bug that just came up, it's the "insertion follows playback bug" where the insertion point after playback nudges back exactly 1 frame. This does not occur on fresh installations of protools 11 but is enables by changing your preferences to "insertion follows playback" in your preference file. This bug is REALLY annoying.
Old 10-16-2014, 07:18 AM
Question Re: Insertion Follows Playback 29.97 df bug
Is this happening with v11.2.1?
Old 10-16-2014, 10:22 AM
Default Re: Insertion Follows Playback 29.97 df bug
Yes, running 11.2.1 HD. The only thing that fixes the bug is deleting all preference files. I think what causes it is if you have under HD preferences "Timeline Insertion/Play Start Marker Follows Playback" checked, then, in the main bar uncheck "insertion follows playback" it'll start to do weird things. Also, if this doesn't make the bug appear try saving and quitting and then reloading the session repeating those steps.
HTML code is On
Playback insertion problem?? Smithcok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2009 04:03 PM
Insertion follows playback weirdness tdowning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2006 06:10 PM
Insertion follows playback. Seeee Pro Tools TDM Systems (Mac) 2 03-13-2006 04:41 PM
"timeline insertion follows playback" BinkBonk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-26-2005 12:18 PM
insertion follows playback KingTor ProControl, Control|24, Command|8 5 05-22-2001 04:23 PM
