Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 10-24-2012, 02:05 PM
monkeysticker monkeysticker is offline
Question Does Pro Tools SE work as a rewire host?
I have an issue with Pro Tools SE using Vocal Studio Producer USB microphone Using Reason rewire.
Seeing that Pro Tools SE is a limited addition I'm not sure whether I can record through rewire with it? And Avid gives no support on the product. Also apart from the manual stating that you can "Show Rewire Clients" there is no information on the topic, not in forums or google anywhere.
This is what I'm doing
I arm an instrument track with the rewire Reason plug in. Reason opens...
In the Pro Tools SE rewire instrument plug-in interface I make sure that reason is selected and that the instrument I want to record is routed correctly through the reason hardware interface.
In the Pro tools SE rewire plug-in interface that particular instrument is selected (eg NN-XT1). Until there no problem the instrument has audio output I hear it perfectly you can see the volume meter lighting up on the master track and instrument track.
I've also looked at the reason sequencer interface where Pro Tools SE automatically sets the reason sequencer L/R that are shown together I don't touch the reason sequencer.
I hear everything perfectly arm the recording start recording but the instrument track does not record any notes.
Is this a Pro Tools SE limitation?
Thanks for your help...
Old 08-16-2016, 06:28 AM
slimmehdi slimmehdi is offline
Default Re: Does Pro Tools SE work as a rewire host?
Hi there,
I got the exact same problem and would like to know if this can be solved? I got an Instrument Track linked to my Reason software via Rewire. I can hear music in Pro Tools, but can't record it. I think I'd need to route that Instrument track via bus to an Audio track to record it, but Pro Tools SE doesn't seem to offer that feature. Can anyone please help me?
My set up is:
Lenovo G580 running Windows 10 Family 64 bits
Intel i5-3210M @2.50 GHz
8 Gb RAM
M-Audio Fast Track
Pro Tools SE 8.0.3
Thanks!
Reaper as VST / AU host - Rewire ? T-Low Virtual Instruments 0 07-06-2010 10:29 AM
Problem with Pro Tools as Rewire Host for Reason 4 midi sordino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-28-2007 03:56 PM
can't get rewire host FL to record into PT?? help! chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-14-2006 08:48 PM
ReWire VST Host: new petition Angus_FX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 119 11-05-2003 07:43 AM
New product : ReWire VST host for Mac OS X / PT6.1 Angus_FX Pro Tools TDM Systems (Mac) 17 09-11-2003 12:09 PM
