Old 10-24-2012, 02:17 PM
12stepcornelius 12stepcornelius is offline
Exclamation PT 10 I/O issues
Hi, I recently opened up a project in PT only to receive the message that my i/o settings have changed, even though I didn't personally change them. The only thing I did do was turn off my FireWire and wifi on my macbook to fix a playback problem. I was recording something and upon attempting to play it back, the sound was only coming through my laptop's speakers, not through my headphones which were plugged into my Mbox 2. I went to i/o settings and sure enough in output it had as current setup, PTAI/O. I click on last saved setup and see MBox 2. Problem is, I don't know how to switch the output path back to MBox. Help please?
Old 10-24-2012, 02:43 PM
C C is offline
Default Re: PT 10 I/O issues
You'll find it under the Setup Menu in Playback Engine.
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 10-24-2012, 03:25 PM
Ok cool. Well I did all of that and got it back to Mbox as the output source, but now the problem I'm having is that PT isn't picking anything up from the bass I have connected to the DI. It was before and now its not after I corrected the I/O issue. I just upgraded to PT 10 and haven't even begun recording after several days because I keep running into issues like these. Why is PT not recognizing whatever I plug into the DI? Its not a bad cable, I already checked that.
Old 10-24-2012, 04:27 PM
C C is offline
Not trying to be difficult or insulting but you may have better luck in posting in this forum area. HDx area is intended for the new DSP line of cards.
Not overly familiar with the mBox intricacies as they stand. The first thing I'd suggest is to clear out your I/O settings and start with a fresh session which has the mBox as it's playback engine. Then hit the Default button in I/O Setup (also under the Setup menu)
This should give you the correct number of inputs, outputs and busses available with your interface. At that point you should be able to configure inputs to the tracks as required. I find that testing is much easier with Aux channels rather than Audio Channels as you'll either receive a signal or you won't, whereas with the audio channels you may need to be in record-ready, input monitoring etc.
Hope this helps somewhat. Good luck.
Ceri
Ceri Thomas
Personal Site
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 03:29 PM
No sound - asio driver issues - NTFS issues mitchelljrickey Windows 0 06-21-2012 05:35 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 08:19 PM
8.0.4 Issues (Quick Punch & Mute/Solo issues) pauledwards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2010 09:35 AM
Digital Noise Issues - Clock Source Issues? Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-07-2010 01:55 PM
