002R /G5/ PT cant find hardware
I have a G5 with dual 2.0Ghz, OSX, running 002R, I have had the system for about 4 months. When I go to launch Protools 6.4 it comes back with the error "Unable to locate Digidesign hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is ready. Meanwhile the 002R is sitting there with the MUTE light on, clicking about once every 2 seconds. It doesnt do this all the time. (Just when I really need it to work right). Anyone got any ideas? I have swapped out the firewire cable, pulled every cable off the back of the 002R, played with the buttons on the front, powered it up and down, pulled the power feed, booted it after the MAC is running and while its looking for the 002R.
Help? |
Re: 002R /G5/ PT cant find hardware
Could be the power to the firewire input - a friend had the same thing happen - may need to take it to the doctor
"...I asked you not to tell me that!" |
It happens to me sometimes (002R/G5 Dual 1.8 old version). Usually I wait about 10 seconds and try again. It almost always finds hardware. When I first got my 002R, this happened. I needed a replacemant 002R. Then it happened again a few months later. I needed a replacement power harness. It's pretty much OK now.
It could be worse. I've lent my 002R to a friend a couple of times. He's on his 4th Digi002 (standalone, not 002R). It's not necessarily the best product, but c'mon ... ProTools compatibility (even 96KHz) for 1,200 bucks. You learn to put up with the crippled features and some staggeringly bad hardware design. |
i have the same problem! its costing me a lot of buisness and digidesign won't answer my questions on the phone. PLEASE HELP!
Can't Find Hardware Problem - I don't use hardware! | sevenk | Pro Tools 10 | 3 | 10-29-2012 09:55 AM |
Help! Digi 002R, OSX 10.4.8 - CoreAudio Can't find hardware | jdimoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-25-2007 07:37 PM |
Fresh install of 6.1.....can't find hardware 002R. | Aoede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-16-2005 10:55 AM |
002R, OS 10.3.9 and LE 6.9 unable to find hardware | smchargue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2005 01:58 PM |
DIGI 002, Problem installing hardware driver "cannot find hardware" on install | inevitable realisation | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 08-21-2003 02:03 AM |
