Old 07-08-2020, 11:34 AM
Vitopower Vitopower is offline
Default Volume fader vs post send fader - same scale?
Having trouble articulating this, so it has been hard to find the right answer.
I build a mix, then I start clipping the input to my master fader.
I go to turn down tracks and now my post fader sends aren't getting the same amount of signal, so the feel of the mix has changed.
-Do I simply turn up all post fader sends the exact amount that I turned the volume faders down?
-Does the behavior change if the fader is below the zero mark? Sometimes if I have staged poorly I have two sends setup to the same effect...when I go to raise the send level to compensate for the change, its doesn't seem that the amount of volume dropped correlates exactly to the amount of send replaced..???
Old 07-08-2020, 12:13 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Volume fader vs post send fader - same scale?
Just turn down the master fader that is clipping. Plugins are post-fader.
Janne
Old 07-08-2020, 12:20 PM
Thanks for quick reply.... I never got that the master fader coming down actually turned down the signal coming into it. Thats a big help
Old 07-08-2020, 12:21 PM
JFreak's Avatar
Master fader controls any output you have in the mixer, whether internal or external. They are there even if they are not visible. Use them to control output levels. Very important to understand to its fullest.
Janne
Old 07-08-2020, 01:43 PM
If I encounter this in an aux, which goes before the master fader, I've got the same problem as before.
what is the math involved to sort out the post fader send change after a volume fader change, or to change
from post to pre fader?
Old 07-09-2020, 06:11 PM
If you turn down all your tracks EXCEPT the AUX tracks(fed by post-fade sends), that should maintain relative balance. While it does reduce what goes to the AUX tracks, you actually want that, otherwise the AUX tracks would sound too loud. I do this all the time as my session templates have the TRIM plugin inserted in the last slot on all AUDIO and INSTRUMENT tracks(not on AUX or Master). The TRIM plugin is set to -8db and all are in bypass during tracking. Once I get to the mixing phase, I enable all the TRIM plugins and the entire mix drops, but balance stays right in the ballpark. And, since TRIM is in the last insert slot, it has no effect on any other plugins on the tracks.
Using fader for send Jazzbass56 Avid S1, S3, Dock and Control App 8 05-13-2020 07:33 PM
10.3 and 10.3.1 Small Volume Fader AND Clip Gain Fader Problem Ale macOS 1 10-11-2012 10:07 AM
volume fader in custom fader mode KimSira ICON & C|24 4 10-15-2008 09:54 PM
Track fader volume to send volume smmdrum Tips & Tricks 9 08-12-2008 05:22 PM
Send a fader Pre Fader?? Peter Groom Pro Tools TDM Systems (Mac) 7 01-02-2007 03:50 AM
