Old 05-06-2020, 11:02 AM
Mattafact Mattafact is offline
Default PT9 HD External Hardware causing a lag
Running PT9 HD on Snow Leopard with a 12 core cheesegrader. It was always been flawless. I decided to create an I/O to hook up my Manley ELOP for mixing. Since then whenever I click on anything I get the spinning beach ball for a few seconds and it just feels laggy.
Any idea what could be causing that?
HDX, Mac Studio, Rupert Neve 511 x 9, Rupert Neve 551 x 8, Manley Variable Mu, Massive Passive, Stereo Pultec, ELOP, VoxBox, and DVC, DBX 160s, Daking Fet III, Distressors, M905 Monitor Controller and other cool stuff.
Old 05-06-2020, 11:11 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: PT9 HD External Hardware causing a lag
You mean hardware insert right?
Janne
Old 05-06-2020, 11:12 AM
Correct. At least I think so.
Old 05-06-2020, 11:13 AM
JFreak's Avatar
I assume you have done it correctly in I/O setup with matching input and output numbers as it should be. What interface are you using?
Janne
Old 05-06-2020, 11:23 AM
I am using the Omni and have the input and output on channels 3-4. I did put in a H/W delay of 34 ms as that is what I measured when I tried printing the drums to another track with it.
Old 05-06-2020, 11:24 AM
JFreak's Avatar
Is it still beachballing if you remove that 34ms adjustment? Just troubleshooting
Janne
Old 05-06-2020, 11:26 AM
It does. Does PT10 improve performance? I have that in my license and haven't tried it yet.
Old 05-06-2020, 11:30 AM
JFreak's Avatar
I cannot say if it helps you with this particular problem, but it may.
However PT10 has many other improvements such as Disk Cache, Clip Gain, Real-Time Fades, 32bit float and interleaved formats, and introduces Avid Channel Strip plug-in. So if you have it, kind of no-brainer to upgrade because it is supported on your Snow Leopard OS all the way to latest 10.3.10
Janne
Top Jimmy's Avatar
If it was working fine before, have you tried trashing prefs and databases?
James Cadwallader
Old 05-06-2020, 11:49 AM
I'm going to try and install it now and see if it improves.
hardware insert causing instability question Measuring Man macOS 0 01-31-2013 04:11 PM
External Preamp with Mbo 2 causing latency. PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-03-2010 06:05 AM
external ad/da causing -6085 errors req06 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-10-2008 06:13 AM
Firmware Update Causing No Recognition of Hardware EarBud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-05-2007 04:10 PM
Hardware drivers causing computer crash rseely 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-09-2006 07:07 AM
