Old 01-17-2019, 02:36 PM
tabonik tabonik is offline
Default Ryzen 32 core
Hi there, i want to buy a pc with a 32 core ryzen processor. Stricktly for use with PT 12. But does PT use all the cores if needed? Or would it be wiser to invest in a different systen? Thanks a lot for your response!!
Old 01-20-2019, 12:00 PM
Meads Meads is offline
Default Re: Ryzen 32 core
For PT a higher clock frequency is more important than core count, since workload distribution is based on signal paths and those are not spread across cores. I wish they would change that, but I don't know if that is even possible.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 01-21-2019, 06:10 AM
True.
What really helps to spread the cpu load is if you use something like Kontakt or EW Play (samplers) is to not use a lot of patches in one instance. Rather use multiple instances of Kontakt or EW Play with single instruments like putting all trumpet articulations in one Kontakt, flutes in another, etc.
Jack
QAPLA!
Old 01-24-2019, 01:28 AM
Jeezer Jeezer is offline
Forget AMD for PT and most DAWs (and lots of other non multicore specific software - so unless you're doing heavy video/3D rendering).
Get an intel 8700k and overclock it 4.8-5ghz all cores on air - noctua cooler + grizzly thermal paste). 6 cores not 32 but the speed AND IPC is important for a lot of software and just behaves better. Adobe suit and other software was optimised for intel CPUs too.
Windows 10 | PT12.8 HD @ 88.2k | ICON D-Command 24 Faders | Prism Titan Converters
Old 01-24-2019, 01:40 AM
Agreed. My 8700k oc'd to 5GHz smokes the iMac Pro. Offline bounce on the iMac at 4x runs at 6.5x on the 8700. Doesn't sound much but really is substantial. And the 8700 machine cost me less than 2k€ vs 6500k€ for the iMac...
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 02-01-2019, 11:37 AM
People thanks a lot for your response. I didn't really expect it and only see it now.. got such a good deal on the amd computer that i couldn't say no. Well it will be a leap forward for me anyway. Let's see..
Old 02-01-2019, 01:44 PM
I still have a question about the use of the cores. I understand it's benefit is regarding multi-tasking. E.g. run different software simultaniously.
How does this translate to the daw?
I mean, when i keep adding plugins and instruments, is the computer then multi-tasking and using it's cores or not?
Old 02-03-2019, 01:03 AM
rossi68 rossi68 is offline
When I upgraded fram a i7 920(4 cores) to a i7 980x(6 cores)(yes, I know these are old ), the performance boost was massive. NI action strings that would stutter and barely run with the 920, was smooth with the 980x. In fact I stick to that machine still.
So my experience is that a greater core count are good for performance in PT
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100
Old 02-07-2019, 05:40 AM
Hi Rossi- Thanks for sharing. Appreciated! Sounds good and i recon the development in daw land since the larger amount of cores become available will be also focussed on that.
Ryzen 2700x or Intel? nunosfr4 Windows 0 10-10-2018 05:06 PM
Im Guessing It’s Ryzen - Playback Issues justindk Windows 9 11-23-2017 02:01 PM
AMD Ryzen Threadripper 1950x lowthert Windows 3 10-19-2017 11:53 AM
AMD Ryzen processors gcasper Windows 14 05-08-2017 01:39 AM
Pro Tools 11 and AMD Ryzen CPU's griff71177 Pro Tools 11 51 05-08-2017 01:38 AM
