Old 09-21-2016, 06:49 AM
jwilkers jwilkers is offline
Default Profire 2626 not working with macOS Sierra
Yesterday, I went ahead and updated to Sierra. As I suspected my audio interface would not work because it is no longer supported by the manufacturer. So, I reverted back. While I was there, I could still open sessions but forgot to check to see if the meter lag had gone away when you open a plugin.
I would like to know if Sierra fixed this before I consider purchasing a new interface.
Sorry, I could have done this myself.
Old 09-21-2016, 07:07 AM
KV626's Avatar
KV626 KV626 is offline
Default Re: macOS Sierra
Originally Posted by jwilkers View Post
Have you tried disabling SIP after installing Sierra? Might be the reason your interface was not recognized. I have to run with SIP disabled otherwise my SSL card is non-existent in El Capitan. Latest driver for the MADI card is from 2011 - good job SSL!...
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 09-21-2016, 08:03 AM
clausiii's Avatar
clausiii clausiii is offline
Meter lag is gone here on Sierra
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-21-2016, 09:36 AM
Rawer Rawer is offline
So all good on Sierra, all plugins cool as well?
Old 09-21-2016, 10:20 AM
clausiii's Avatar
Well, all good HERE, but i don't recommend it. I don't know your system.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 09-21-2016, 10:34 AM
weezul weezul is offline
all good for me apart from Mini Grand... Two different systems both have the same problem of cut-short samples.
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 09-21-2016, 10:48 AM
KV626's Avatar
It was gone for me in 10.11.6 - I just installed Sierra and there's absolutely no difference at all regarding PT's performance. 100% identical. If it's impossible to install Sierra on 1/2,1 Mac Pros, that's kinda comforting at least!
Old 09-21-2016, 11:20 AM
I have 2 Profire 2626's. M-Audio flat admits that the hardware will not work after osx.
Old 09-21-2016, 09:07 PM
Seafoam_Green's Avatar
Seafoam_Green Seafoam_Green is offline
Hi Rawer,
Which plugins , and on what system are you running them on ?
cheers.
Pro Tools 2021.6.0 Native * Slate Raven MTi-1 Version 3.9.1 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.0 GHz 10-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D700 6GB * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 * Samsung SSD's 850 Pro * WD Black HDD's
Old 09-21-2016, 10:22 PM
clausiii's Avatar
Did they tell you why?
They did Capitan drivers then. I bet they work in Sierra too.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
PT on macOS Sierra? eesn Pro Tools 12 66 10-01-2016 11:46 PM
macOS Sierra 10.12 not yet supported Avid Technical Alerts 0 09-20-2016 10:34 AM
Profire 2626 working with PT 11? necjamc Pro Tools 11 8 06-26-2013 09:50 AM
Signal from Profire 2626 to pro tools isn't working properly beasleymusic Pro Tools M-Powered (Win) 2 08-21-2010 08:09 PM
