Change one insert on a track - change all tracks with same insert
How is this done? I've tried CTRL-OPT and I can drag and drop the same insert, but I haven't found a way to change an inserts settings on one track and have the same settings apply to the same insert on different tracks.
Re: Change one insert on a track - change all tracks with same insert
have you tried selecting the tracks you want this to happen to and add SHIFT to the button combo?
don't know if it will work
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Yes, that didn't work.
group the track then look into the attributes area of the groups dialog box and choose the insert slot you want linked.
I'm pretty sure it only works on identical plug ins. at least that would make sense. . but Ive never tried with say different eq's I just use the same plug in in the same insert slot and changing one instantiation changes all the channels.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
option + shift
kasper |
SO theres is no need to copy and paste the setting. Just adjust one channel's eq or whatever and all grouped/linked channels adjust also. EDIT>>> Right you said "as above OR" . . . sorry, I missed the "OR" part.. Yeah copy and past is useful for plug in settings also!!
Fx insert , preset change autmation | Shanti Monkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-03-2010 06:40 AM |
help! insert the tempo/meter change in the session | iamjungle | Pro Tools TDM Systems (Mac) | 13 | 04-26-2010 10:20 AM |
Loop tracks stuck together - change 1 change all | jrwallace | Pro Tools M-Powered (Mac) | 1 | 02-22-2010 09:19 PM |
Change insert A EQ to Dynamic C/24 | TCDet | ICON & C|24 | 2 | 09-04-2008 07:37 AM |
BDF insert - can't change tempo | habernacks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-27-2006 11:52 AM |
