Wow am I tired of reboots. I've literally spent most of my day yesterday and today as well as hours of the previous two evenings trying to get PT10 installed and working 100%.
I'm still missing plugins. This page lists what plugins are supposedly bundled with PT10. I don't see any of the AIR plugins. The only Verb plugin I can select is DVerb. I'm about to go through the above page like a checklist and find every plugin that is missing. Yes, I have installed the 10.0.1 update as well as the virtual instruments installer. I have installed all of the factory plugins listed on this page. I usually hate writing installers but I'm considering asking Avid to hire me to rewrite their installations. |
Can't speak for PT10, but sometimes, earlier installers have mistakenly stuck some plugins into the DAE/Plugins(unused) folder. Dragging the files into the Plugins folder solved that(so its worth a look anyway).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
![]() Quote:
It generated an error saying I had more than one mixer (either stereo or surround) plugin. I found both a regular and a dithered plugin for stereo and for surround. I wasn't sure what to do, so as a guess I moved the dithered plugins back to unused and pro tools loads again. Still missing a lot of plugins. |
Looking for AIR plugins I find folder C:\Program Files (x86)\Common Files\Digidesign\AIR which is next to, not under the Plugins folder. DLL files, not DPM or RSR files.
Still searching for info on how to get those enabled. |
There's 2 folders to look in unused plugins. Go to application support. There's an Avid and A Digidesign. I think the AIR are in the Digidesign one. Look in unused.
Thanks for your reply.
The AVID unused plugins folder is empty. There's something deeper wrong. |
Hi
I get the same except for finding the D-verb plug-in http://duc.avid.com/showthread.php?t...ighlight=click In case I get any solution, I'll let you know. Please keep me posted as well if vice versa. Best of luck, Ruxandra. |
Tonight I will probably uninstall the heck out of everything (AGAIN), then delete all related folders and manually go through the registry deleting any Digidesign or AVID related entries, then try reinstall.
If THAT fails I'm going to drop back 5 and punt. |
I've managed to fix it. Check it out http://duc.avid.com/showthread.php?p...96#post1908696 Best of Luck and Hope it works out for you as well!! |
![]() Quote:
REALLY appreciate you sharing the info. So, you had to install Pro Tools before installing the driver for your hardware interface? If so that's strange because the instructions that came with the 11R said to install driver before installing anything else. And installing specifically in that order allowed your plug-ins to show up? In my case I already had PT8 and Digi 003 Rack Plus, but the drivers disk had updated drivers for that as well. So, I installed both drivers before PT10. I'll have to try this, tho probably won't have time til later this week. |
30 Days of Night: Dark Days nominated for two sound awards | Eric L | Post - Surround - Video | 2 | 01-21-2011 08:03 PM |
Audio from past two days of recording missing... ideas? | keevhren | Pro Tools TDM Systems (Mac) | 25 | 09-15-2010 05:48 AM |
DV Toolkit 2.0 install, missing plugins... | Adman44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-01-2010 03:29 PM |
Help please. Post PT 8 Install all plugins from past sessions are missing! | Buster1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-20-2008 05:29 PM |
Plugins missing in drop down list, but in plugins folder ?? | mixingmadness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-12-2007 11:27 AM |
