Old 11-21-2002, 09:43 AM
peter parker peter parker is offline
Default Anyone use JAM v.2.6 with OS 9.1 or higher??
curious because the JAM booklet says it supports Mac OS 8.6 up to Mac OS 9.0.4 ......
i installed v.2.6 on OS 9.1 and the g4 totally freaked out there for a minute after freezing on the restart. it took 2 more restarts to get things running ok again. wonder why it just wigged out like that? it seems ok now.......anyway i burned an mp3 to cdr .....went ok.....no problems......so my question is if anyone has had any problems running JAM v.2.6 with OS9.1 or higher....... do u get weird pop ups about not being able to recognize the cd recorder....which is odd, because it still seems to burn ok?
Old 11-21-2002, 09:50 AM
crowdog crowdog is offline
Default Re: Anyone use JAM v.2.6 with OS 9.1 or higher??
I've used it with 9.1 and now 9.2.2 with no problems at all .......... it's been smooth as always.
Tony
___________________________________________
Mac Pro 2 x quad-core 2.8Ghz / 14GB RAM / OSX 10.6.8/ PT10.0.1 / 003R
Old 11-21-2002, 10:00 AM
GORILLA GORILLA is offline
Same here Jam 2.6.2 on a G4/400 9.2.2 Never a problem.
I ran Jam on my Que Fire firewire CD-R drive when the Jam website said it wasn't supported! It runs great.
METAL LABS
Old 11-21-2002, 10:38 AM
Dead River Studio Dead River Studio is offline
When I upgraded to 9.2.2 Toast would not recognize my Que firewire CD-RW. It was because the OS upgrade installs iTunes extensions and they conflict with Toast when they are both all enabled at the same time. I had to disable iTunes extensions and create an extension set for running Toast. Now it works fine on 9.2.2.
This may also be what's happening to the Jam application. It's worth looking into it.
Steve
My studio... http://www.deadriverstudio.com
44.1 kHz vs. 48 kHz - why not use the higher? Mr. Kelly Tips & Tricks 117 08-13-2017 04:44 PM
going higher than 10.6.3 viaspiaggia Post - Surround - Video 2 06-23-2011 05:41 AM
Can I get mp3.dll from 6.7 or higher? jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-13-2006 02:54 PM
Anyone running higher than OS 10.3.4 with 001? duderonomi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2005 08:59 PM
Higher Gain Tommyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-22-2000 07:48 AM
