Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 11-27-2019, 01:33 AM
mat.mat mat.mat is offline
Default Best way to route signal at mixdown stage in Pro Tools 2019
Hi there, last time i've been working with pro tools it was 2009 (PT 7.4).
After 10 years i finally renewed my rig and got PT 2019 with an Apollo x8.
I have a question for the pros out there,
i've seen there are many new features in the current PT version and i think i have to re-learn how to use this software properly.
Anyway my questions are:
how do you guys print the final mix in PT 2019? (bounce to disc or print to a stereo audio track)
what's your favourite routing to get the mixdown printed with the actual PT version?
for example, i would group tracks using the new VCA master fader feature then routing any of these groups to stereo Auxes, then would buss-sum all Auxes using a Master fader, then would buss the resulting sum to an Aux (router) where i would insert eq and comp plugins for glueing the mix and finally would buss this router to an audio track input for printing the final stereo mix.
Is this the best way to go?
or is it better to end the chain at the master fader inserting eq/comp there and bounce to disc?
thanks
Old 11-27-2019, 02:40 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Best way to route signal at mixdown stage in Pro Tools 2019
Hi, welcome to the community.
Basics have not changed. Keep it simple as long as you can; but when you need to (for example mixing a drum kit) sum the tracks with aux and group them to control with VCA.
Every processing (plugins and routing) changes the game a little so in theory you get cleanest sound by outputting all tracks to your master output.
Janne
Old 11-27-2019, 04:52 AM
Ben Jenssen's Avatar
...of course, plugins on master tracks are post fader, aux'es and other types of track are pre fader. Big difference.
Old 11-27-2019, 06:30 PM
SDDP SDDP is offline
thanks
PT 7.4.2 was probably the Most stable PT I've used. I stayed on that for years and ONLY went to 9 for some serious updates I needed and thought I'd stay on it for years and years. Till 11 came out with the 64bit that changed everything. Then I was set on that and thought I'd stay on it for years and years. Then 2019 came out with an extra 128 tracks for HDN. HUGE benefit. Since getting more than 256 tracks with HDN, I'd have to go to 2 HDX cards costing over $5,000. So I am going to stay on 2019 for years and years...Till...
Sorry for going off track, but you've got some serious new features going from PT7 to 2019.
The ONLY way I would every upgrade again is if they give multiple audio bins and NO MORE -9173 errors.
-Mac Pro 5,1 12core 2.4GHz Westmere 40g
-RX 580 8GB GPU
-OSX 10.12.6 on a 1TB SSD Via PCIE card
-PTHDN 2019.5 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX7 Advanced
-iZotope Post Production Suite 3
-iZotope Music Production Suite 2.1
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 09:12 AM
How to route a mono outboard signal into a PT stereo aux track? Blues Bird Pro Tools 12 6 11-04-2016 11:40 AM
Mixdown on Outboard Console - How Do You ROUTE? innermusic Pro Tools 10 11 05-03-2012 03:09 PM
Losing stage link to 2nd stage rack sonicboost VENUE Live Sound Systems 7 11-15-2009 02:43 AM
Why the audiosuite audio signal can-t route to a bus? sonuslab Pro Tools M-Powered (Win) 0 03-25-2008 02:26 AM
