  #41
Old 04-17-2017, 10:41 PM
Damontozer Damontozer is offline
Default Re: Pro Tools ERROR 1104
Any Solution yet?
  #42
Old 04-17-2017, 10:42 PM
Is everyone here using a Mac book?Is everyone here with this problem using mac's?
  #43
Old 05-01-2017, 08:16 PM
ashleyjknowlton ashleyjknowlton is offline
Originally Posted by Ejano View Post
Hello,
Im getting this message when trying to open up session:
Could not complete your request because Assertion in "/Volumes/Development/200028/ProTools/NewFileLibs/FF/Audio/FF_AudioFile.cpp", line 1104.
Has anyone had this error, if so how did you get rid of it>>>>Thanks
My system:
Pro tools 12.7.1
OS X El Capitan
Version 10.11.6
Scarlett 2i 2
Hi Everyone!!!!
I have been having this problem for over two months. I JUST FIGURED OUT HOW TO WORK AROUND IT!
Hope this works for some of you:
I consolidated the files from media source and created a new AAF into a NEW FOLDER labeled AAF EXPORT (I found that if you do not make a new folder, your project will get very messy and hard to find). This process copies & renames all the clips and works around the AAF corruption. I have found that the assertion error wasn't for the audio or media files- but within the AAF. (Video Editors may be used to working this way when using AVCHD or RED files... Most of the times it is called making "Proxy Files".)
  #44
Old 05-01-2017, 08:18 PM
Ejano Ejano is offline
You have to open a new session, import tracks and find the corrupted file....
  #45
Old 09-01-2017, 10:57 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
I have this happen consistently with OMF or AAF files from Logic 9 from some clients of mine.
The solution is to import the audio and immediately commit or consolidate the regions and then delete the old tracks and files (select unused, clear). Commit with delete is quicker and cleaner.
Also, when these sessions won't open, you can still open them in PT10 most times, then do the consolidate and clean, save, reopen in PT12.
  #46
Old 11-22-2019, 05:16 PM
Jonnypgray Jonnypgray is offline
Here's my post from last week re ERROR 1104
In my case I get it when I try to import an aaf made with Media Composer 2018.11 or made with Pro Tools Ultimate.
http://duc.avid.com/showthread.php?t=407212
Might help you identify an issue in your case
JonnyPGray
- Pro Tools 12.7.1
- HD Omni Interface
- Windows 7
- Service Pack 1
- x64-based PC
- Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
- RAM 8.00 GB
  #47
Old 11-22-2019, 05:58 PM
Southsidemusic's Avatar
This is a 2 year old thread fyi! I think he has solved his problem by now
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
Pro Tools 8: Activation code not working/Error: Data Error (cyclic redundancy check) Mattmattmatty Windows 2 05-01-2013 04:26 AM
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
Pro Tools Creative Collection returned an error. Error: -2147213312 sirprotools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-24-2011 06:17 PM
Pro Tools Creative Collection returned an error. Error: -2147213312 THAPRODUCERZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-05-2010 02:14 PM
