#441
Re: Moving to Reaper?
It's not quite fair to call it silence. They do speak. But everything anyone says on the company's behalf has to be cleared first, probably by a committee, more or less. A big ship just can't turn as fast as a small one. That's understandable.
PT still has a virtual lock on the pro studio scene. That will buy them a little time. Not a lot. If they started two or three years ago reprogramming PT from scratch using a current OOPs, PT might survive. But I'm not holding my breath. If they're still trying to build on the original code, forget it. The ship is going down.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#442
I got all excited and installed reaper at home......and it didn't work properly.
#443
Have you configured your I/O, soundsource, etc...?
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
#444
I'm guessing it has something to do with using the onboard sound card. Worked fine on the laptop and work PC. |
#445
...or just use the DigiASIO driver with your Digi hardware I/O. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#446
The Reaper came for Protools.
Here lies ProTools RIP 1991-2010 You won't be missed.
q6600-ASUS P5K SE(P35),2GB Crucial BallistexDDR2 800,ASUS EN7200GS 256MB,80GbMaxtor-80GBWestern Digital,Samsung SATA DVD burner,Mbox2 PTLE 7.4cs7 |
#447
Eh. I've been exploring Reaper for a few days now and I'm not as impressed as I expected. Nearly everyone acknowledges that PT has the upper hand when it comes to editing. But I'm finding it also still has the edge when it comes to reliably yielding professional results. If PT can't make it sound right, it almost always stops and throws up a red flag. Reaper, like most other DAWs, will go ahead and play back, giving you crap sound if it can't do anything else. Not good. I have a huge preference for PT's get-it-right-or-shut-up approach.
#448
Frankly, if you are counting on a DAW to create a sound for you, or "throw up a red flag" when you, as the user, makes a bad audio choice... you are expecting too much.
PT won't "make it sound right" any more than Cubase, REAPER or Sonar will. Actually, I'm not sure I really understand your post. Are you faulting REAPER because it doesn't produce Digi error messages to prevent you from going ahead with a bad mix? |
#449
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#450
OK, lemme esplain. I put one track in PT, then I put the same track in Reaper and rewire it in. I flip polarity on the track in PT. They never completely cancel, sometimes they mostly cancel, sometimes they don't cancel at all, sometimes they change latency during playback. After 15 years of daily use, I know the problem isn't PT. It's the audio coming from Reaper that's not consistently coming through bit-for-bit.
Also, throw a few VIs into Reaper, and sometimes some of them just output staticky, bit-crushy junk. Sometimes they do fine, sometimes not. Not consistent. Not pro. I know PT 8.x has lots of horrible problems (which is why I'm still on 7.3), but despite all that, when it works, it's pro. Reaper is not yet pro. I hope it will be when it grows up. But it ain't yet.
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
Reaper 4 in Protools Help.. | egrideout | macOS | 7 | 12-23-2011 07:17 AM |
If you're moving to Reaper get on with it! | rqstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 32 | 04-04-2010 03:44 PM |
Reaper! thats a bit embarassing! | Gravyblue | General Discussion | 78 | 10-26-2009 02:12 PM |
Reaper and Pro Tools 8? | jebwick | General Discussion | 50 | 09-23-2009 07:20 PM |
