Old 04-11-2005, 01:07 AM
duderonomi duderonomi is offline
Default Anyone running higher than OS 10.3.4 with 001?
I have recently converted my 001 over to 6.4 PT. I am running 10.3.4 as it has been approved by DIGI.
However, since DIGI quit testing after 10.3.4, I was wondering if anyone is successfully running higher OS versions?
I appreciate any input.
On a side note. I cannot get audio to play through my 001 when using Toast to playback two mixes. I have the 001 selected as the output source in my sound panel.
Thanks
recording engineer=audio photographer
Old 04-11-2005, 09:51 AM
Firewire Firewire is offline
Default Re: Anyone running higher than OS 10.3.4 with 001?
My setup is Digi 001, G4 dual 533 with Gigadesigns dual 1.2Ghz upgrade 1.5GB Ram. Audio drive is on internal ATA66bus.
I'm using ProTools LE 6.4 cs9, and its very stable. The only odd behaviour I've encountered is every once in a blue moon (couple times per week) the edit window display locks up. I close and reopen the window and all is fine. I do not use the Core Audio Driver as it screws up my other apps causing crashes etc.
Old 04-15-2005, 08:59 PM
sdgard sdgard is offline
I can get Toast to play back only through the G4's internal sound out. Toast just ignores the 001. A nuisance not to have them both (PT + Toast) running at the same time, but non possimus.
SDG
44.1 kHz vs. 48 kHz - why not use the higher? Mr. Kelly Tips & Tricks 117 08-13-2017 04:44 PM
Can I get mp3.dll from 6.7 or higher? jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-13-2006 02:54 PM
Who's running software higher than 6.1 on a D24? Shawn B Pro Tools TDM Systems (Mac) 3 08-02-2005 01:30 AM
Anyone use JAM v.2.6 with OS 9.1 or higher?? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 10:38 AM
can hd timestamp its files when running @ 96K or higher??? ejsongs Pro Tools TDM Systems (Mac) 4 03-17-2002 11:45 AM
