Old 06-04-2011, 02:21 PM
Riversound Riversound is offline
Default HELP with Protools LE 8.0.4 / MBOX3 / Plugins WAVES.. problem
Hi people!!
First! sorry for my english!
Second....
I need your help!
This is the issue...
Until yesterday I work with Protools 7.4 M-Power with the M-Audio “delta 44”.
Works perfect under Windows 7 64 bits.
I had installed the Waves Diamond Bundle.v5.2 plugins.
All works fine.!!!!!
Yesterday.
I get my new MBOX 3 that comes with Protools LE 8.0.4
Works GREATTT!! in windows 7 64bits
But the problem is the Waves Plugins.
I install them.
And when I run a protools session and try to use any of the Waves plugins
in audiosuite.
The protools quit off and make me restart the machine.
Any help?????
Please!!!!!!!!!!!!!!!
Again!! Sorry for my terrible english!!! But in my language (Spanish) nobody could help me!!
Old 06-04-2011, 07:16 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: HELP with Protools LE 8.0.4 / MBOX3 / Plugins WAVES.. problem
Waves v5.2 is quite a few versions back. The latest is v8r7. You may have to update your plug-ins as they may not be fully compatible with version 8.0.4 of Pro Tools LE.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-04-2011, 08:42 PM
theres a Waves version 8 for ProtoolsLE 8.0.4 compatible with windows 7 64 bits???
Old 06-04-2011, 10:27 PM
mano111 mano111 is offline
Yes. You need to upgrade to waves V8
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 06-05-2011, 04:00 PM
Well I install finally the windows 7 32 bits.
For use the WAVES v7
Some plugins works and other plugins like Soundshifter or other pitch plugins.
Give me this error
"integer error occurred (divide by zero) at address: 0x2F2D8C6A in module: Soundshifter.dll"
some idea????
thanks!!!
Old 06-05-2011, 06:25 PM
The Weed's Avatar
I believe you need v8?
Cheers,
SonoBus
Weird problem with Waves plugins seanmccoy Post - Surround - Video 5 11-01-2013 05:40 AM
PT LE 8 problem with Waves Plugins Twintone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-01-2013 11:00 PM
Problem with Waves Plugins Farthat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-31-2011 09:29 PM
Waves plugins flickering problem a_mendritzki Pro Tools TDM Systems (Mac) 2 03-17-2011 09:03 AM
Protools can't see Waves plugins DMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-04-2003 12:10 AM
